Results 1 to 11 of 11
    Dec 2018
    Default VOLVO C30 D5 2.4 HELP
    Good afternoon all.
    I was hopefully looking for some help
    EDC1631 Volvo c30 2.4D
    Customer damaged original ecu BUT i managed to clone with Ktag 7.020 eeprom and flash
    I bought matching numbers ecu. 100%
    Then loaded cloned flash and eeprom with DPF EGR and tune
    Car started few times ran , then cut out
    Fault code showing 3A00 faulty software. Faulty signal. I think maybe chks but not sure
    Ive uploaded all files
    a500tut's Avatar
    Jun 2017
    Belarus
    Try and report password after thanks and rep!
    If I helped you, click thanks and reputation
  3. The Following User Says Thank You to a500tut For This Useful Post:
    MVRH (16th August, 2019)
    Dec 2018
    thanks i will test and report tomorrow
    Dec 2018
    Exactly the same, starts then cuts out
    Dec 2018
    I've tried several files now
    Can I confirm to clone correctly it is just flash and eeprom as I'm loosing the will.
    Or should I only transfer the eprom on volvos and mod the replacement flash as opposed to the ori
    Babos's Avatar
    Mar 2012
    you eraset all diagnostic codes and now you try understand what problem is in car?
    Nov 2011
    EU
    I think... You just bricked this ecu while opening. Its not sw issuse but hardware issuse, even if it started first time, I had same problem
    Dec 2018
    I've got another ecu coming. I suppose it's possible it's one with bdm pads on the underside however it ran on original OK ran on mod OK for 5 minutes now starts and cuts out.
    Fault code incorrect SW
    No signal from throttle module due to above
    So thought checksum, solution or immo
    Someone must have experienced similar issue, I personally have not in over 5 years not like this.
    So on the replacement should I still transfer flash or just the eeprom. Could the original read in fact be junk??
  10. #9
    a500tut's Avatar
    Jun 2017
    Belarus
    Please do not worry, your file is not garbage, otherwise it would not start at all.
  11. #10
    Nov 2011
    EU
    If you get ecu with same numbers than only eeprom is enough. Than you can read flash using k line.
    Maybe better to drill hole to bdm pads than opening this ecus.
  12. #11
    Dec 2018
    @a500tut I didn't mean your file I just thought maybe the original read was junk. Must be the ecu
