    Feb 2013
    UK Bristol
    Default BMW 318i E91 (SIEMENS MSD80) Dtc Off
    Hi There lads :-)
    I need small helps with switch off just one DTC code from ECU: 2AAF
    car is BMW 318i E91 (SIEMENS MSD80)
    Many Thanks
    My post helps you? Please Hit Buttons
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    Default s
    here it is
    Chiptunning / EGR / DPF / FAP / DTC / FLAPS / Adblue / ETC.... CUSTOM SERVICE / FILE SERVICE / 24/7 Support
  3. The Following User Says Thank You to Ignasvw For This Useful Post:
    pocinas (17th August, 2019)
    Feb 2013
    UK Bristol
    Thanks a lot. Rep and Thanks done. Will test tommorow and let you know
    May 2018
    Kess clone read and write this ecu ?
    Wysłane z mojego SM-G973F przy użyciu Tapatalka
    May 2017
    Yes,hear some did it, another dont... but need good power and only obd kess.. ktag dont.
    Feb 2013
    UK Bristol
    I use kess 5.028 clone and read it this, but dont write yet, but how said Lambda1. Must connect extra good power because reading of this was 55min.
