Results 1 to 10 of 10
    Digital Under's Avatar
    Oct 2017
    Default HONDA Civic: Problem with cruise after remove dpf
    Hi to all.
    problem solved
    wrong gearbox
    Jul 2012
    obvious the problem is in the modified file !!
    Sep 2016
    contact with me, i know how edit this file.
    FILE SERVICE
  4. The Following User Says Thank You to voltechcar For This Useful Post:
    TPS (21st August, 2019)
    Oct 2017
    Quote Originally Posted by mario38 View Post
    You sure?
    You checked file?
    On ori file cruize not work too after several km. But in car filter empty
    Oct 2017
    Can anyone check file?
    Mar 2015
    What year of car and engine ?
    Oct 2017
    Quote Originally Posted by dudson86 View Post
    2008 year
    What it matters?
    dimitar's Avatar
    The cruise wont work if you have a fault code
    50w Soldering Iron
    Chisel
    Sometimes Hammer
  10. #9
    Oct 2017
    Quote Originally Posted by dimitar View Post
    On mod file car have only one dtc - p0380 (glow plug), on ori file car have many more dtc' for dpf and p0380 too.
    On mod file this dtc appears imeddiately after ignition on, but cruise stop working after several km. Not sure what problem in glow plug
  11. #10
    bobolin4o's Avatar
    Bulgaria, V. Tarnovo
    The file is ok, even a single DTC not suppressed! And with this file you don't have an error codes about the DPF at all! Just think about it...
    The cruise may stop work, because of the improperly regulated clutch/stop light switches!
    About P0380... i don't know if this DTC can cause the cruise control to stop...
    Contact your tuner and ask from him to disable glow system monitoring...
  12. The Following 2 Users Say Thank You to bobolin4o For This Useful Post:
    pike (23rd August, 2019), stanislav georgiev (23rd August, 2019)
