Results 1 to 3 of 3
Threaded View
    Dec 2018
    Default 06a906032hj remove vvt help
    recently fastened an agu head to a bbu bottom end and put it in a audi a3 running me7.5 it has an ihi turbo that makes ko4 look like a babies toy and bosch green injectors that are period and fittment correct for the agu set up.
    the issues im having are theres vvt codes which i am able to map out but i dont know if the actual function of the vvt needs mapping out to correct second issue of car performing like it has a popcorn limiter at 5500 rpm
    so iv ditched the ecu it came with got hold of an ori ecu for the car and an ori file to start a fresh map but fell at the first hurddle with the vvt.
    any info help etc would be much appreciated
