hi,
can help remove dtc P0420
simos 3.4a
8E0906018AM
hi,
simos 3.4a
8E0906018AM
i did p0420 remuve
pass in pm
Don't forget hit thank button if i helped.
plam1972 (19th August, 2019)
Can I have password
I have same problem in skoda 1,2 htp
I try to find by myself and with others but without sucess
fodortms (18th February, 2021)
attached
thanks I will test it
Hello, can you check my file? They said is Lambda 2 dtc off p0420, but the file is the same as ori. Attached is the Log with "mod" file and the ori flash. Thank you. And if you can turn off dtc p0420, I will be pushing those buttons.
volodin69 (20th May, 2021)
Thank you. I will come back with a confirmation.
Post edit: YES, never appeared the DTC. Thank you, vitaliyl!
Hi mates:
Is possible delete DTC P0420 in simos 3. IŽll try but DTC come back.
Thanks. B.R.
raspic (11th March, 2025)
