Results 1 to 8 of 8
    Netherlands
    Default TCU dtc remove - Audi A8 3.7 v8 D2(4D)
    Hi all,
    I have Audi A8 D2 2000r facelift w automatic tiptronic transmission HP5 from ZF.
    TCU no. 4D0 927 156 AF
    Problem in this car is permanent DTC P1820 Pressure Control Valve 2 - Short to plus.
    There is no real short to plus, probably TCU has internal failure. When I swap valve 1 connection line with valve 2 there is still DTC P1820 Pressure Control Valve 2 - Short to plus. No DTC code about valve 1.
    Is possible to remove DTC 1820 from flash memory to prevent limp mode.
    In attachment dump of flash 29F200BB from TCU
    I hope you can help me solve this.
    Best regards
    impossible is nothing...
    vasko's Avatar
    Nov 2011
    Gotze Delchev
    open ecu and post pic inside.i will say which chip problem
    Netherlands
    Quote Originally Posted by vasko View Post
    Here you are this is my TCU inside view.
    vasko's Avatar
    Nov 2011
    Gotze Delchev
    vasko's Avatar
    Nov 2011
    Gotze Delchev
    30349? number chip i cant seen
    vasko's Avatar
    Nov 2011
    Gotze Delchev
    this chip commanded valve 2
    change swap with other from board
  7. The Following 2 Users Say Thank You to vasko For This Useful Post:
    poki123 (28th August, 2019), SALAS (28th August, 2019)
    Netherlands
    I have 3 the same modules every one is broken in another way. But one is in virgin condition (newer opened before) with valve 2 fault also
    Yes the big chip is 30349. But I have fault of valve 2 in every module.
    I can open 3rd module but when I 'll swap from another that I have I think it give me fault again.
    Jan 2021
    Russia
    ENGLISH ONLY !!! abd no addys.
