I have this A8 lost key,4E to look at, the garage lost the customer key, its 3 lit. diesel, the car has prox, function but has normal ignition, i only have avdi, can this be done via obd? can kd remote be used, if yes what part no pls? sorry for vauge questions but thats how much the garage told me, thanks
nazz2 (20th August, 2019)
Btw,
If I remember well kd remotes are working to start the car but the buttons not working well...
Something like trunk button will unlock the car,lock button will unlock trunk..I don't remember well.
I also seen they done an update on a8 remote.it may work well now.
Is the original key and remote are integrated? ie id 46 remote gets programmed at the same time? or is it a manual procedure? i have to get more info from the garage but he said this car has normal ignition.(no push start) so maybe no kessy, not sure will let you know. Do you know what p/n it is? i have only found one A8 in the old zone, thanks
Yes,is id46 in circuit.
Remote will program automatically.
I used touareg key, worked well.
I'm not sure if all a8 are keyless but the one I've done had ignition too.
Ignition will turn on and start when pressing the brake pedal.
Keyless keys 4e are very hard to find.did not found on eBay or China.
And is kessy..
In kd app..
Go in "vw Skoda seat".you will find a8,touareg, Phaeton..
Also you can try Touareg 433 nb multifunction.
Thank you very much comizelu, alot of good info. one last question, on right hand drive cars like in uk, is kessy still under the driver seat?
nazz2 (21st August, 2019)
easy from dump
6841707059 576F526B 57416E5453 596F55 526F6B69424152
Oh well customer found spare key, so i am going on Friday to do a spare KD remote, hopefully kd would do it, will update the post,thanks again guys.
