Results 1 to 9 of 9
    Portland, OR, US
    Default 2000 Toyota Land Cruiser all keys lost
    Hello, friends. I need help programming key for this car. Someone else tried, and maybe corrupted dump, not sure.
    I include original dump anyways. If its corrupted, if anyone has, help me please with a good one. I need to program this key into ECU dump.
    ECU 89666-60170 93C56
    Tiris 4C key:
    stream: 00007E2E84FCD00000000022FB7E0000
    data: 000000000B3F2174
    Thank you.
    droidwayne65's Avatar
    Aug 2015
    North America
    Quote Originally Posted by visavis88 View Post
    Tiris 4C key:
    Thank you.
    LOL! Poor eeprom, it's useless as a source of info. I don't have a file for that particular ecu but I have others with what I hope is your LC format. Try writing this one and test whether the ecu still comms and even starts the car, then we can go from there.
    <---- Coin of the Realm.
  3. The Following 2 Users Say Thank You to droidwayne65 For This Useful Post:
    newone (21st August, 2019), visavis88 (21st August, 2019)
    Portland, OR, US
    ok. so with original ecu dump, ecu communicates, but there are no DTCs. registered keys number is 0. security light is flashing.
    with your dump, there is code B2795 Unmatched Key Code. security light is flashing.
    ray-ray's Avatar
    Is there 4 plug in the ecu or 5 ? You can also flash it non transponder .
  6. The Following User Says Thank You to ray-ray For This Useful Post:
    visavis88 (23rd August, 2019)
    Portland, OR, US
    5 plugs ecu. Would you be able to add that key in the ecu dump? I don't have no immo file for it.
  8. #6
    Aug 2015
    North America
    Wrote it as 8 or 16 bit? Is that "7E2Exx" your key's TIRIS data?
  9. The Following User Says Thank You to droidwayne65 For This Useful Post:
  10. #7
    Portland, OR, US
    yes, wrote it as 16 bit. and yes, this is my key 2E 84 FC D0.
  11. #8
    Portland, OR, US
    looks like the problem is fixed: car tries to start now (maybe bad spark plugs), no security light. for those who is looking for solution, working dump is attached, fixed by AVDI. Thanks to droidwayne65 for his dump.
    • File Type: rar ok.rar (151 Bytes, 32 views)
  12. The Following 4 Users Say Thank You to visavis88 For This Useful Post:
    just4upal (14th December, 2021), Ke11er (20th July, 2023), Slem (12th December, 2021), XOCHITL (16th August, 2023)
  13. #9
    Slem's Avatar
    Oct 2015
    I would like to thank to share this file, I faced the same issue with the same ECU and fixed by your dump. thanks and rep. already added to the thread.
    Slem
    Anything is possible if you don't know what you are talking about.
