Thread: 330D E46 184HP
    Feb 2019
    Default 330D E46 184HP
    Hi guys i've been tuning around with my 2000 e46 330d and i've wanted to ask some opinions about where i'm at this point, i'll attach the tuned file and the original one, i'm aiming for around 220 horse power but i'm not sure if 70mg will be enough since that's the point that i'm at, i'm pretty sure its around the 200hp from how the car behaves, if anyone could help me reach the 220 mark i'd be gratefull.
    a500tut's Avatar
    Jun 2017
    Belarus
    I think 70mg is good for 200ps, but for 220ps y must be up to about 78mg and pressure to 1.5 bar.
    If I helped you, click thanks and reputation
    Feb 2019
    Quote Originally Posted by a500tut View Post
    Could you give me a help with that, if I'm not mistaken the duration maps only go up to 70mg and to be honest I'm not really sure what to do to get around the 80mg mark
    Jun 2019
    Quote Originally Posted by sepearman View Post
    You need to change the axis to tell it what to do at 80mg, I would remove one of the lower down axis points and shift everything back so you have a free column at the end for your 80mg values, otherwise everything over 70 will behave as your 70mg column does
    a500tut's Avatar
    Jun 2017
    Belarus
    You must change duration maps and enjoy!
    Feb 2019
    I changed the duration axis and gave it a little more boost, can some one give me an opinion?
