Results 1 to 5 of 5
Hybrid View
    Dec 2015
    Default help !zafira B 1.7cdti ecu read and write
    hello
    any one here have tried to read and write zafira b 1.7 cdti by mpps v18 china clone ?
    alldecode's Avatar
    Jan 2010
    EU, Croatia
    i interesting too
    i need to read Astra H a17dtj, ecu is Denso, with mpps v18, are is R and W OK?
    mancioks's Avatar
    Feb 2017
    Germany
    With EU clone v18 all ok. Also kess 2.23 tested ok
    If i helped, don't forget push thanks + rep
  4. The Following User Says Thank You to mancioks For This Useful Post:
    TPS (21st August, 2019)
    May 2014
    LIthuania
    Quote Originally Posted by mancioks View Post
    yes i can confirm that too.with kess 5.017 chinaclone you can even read eeprom also make cloning of this type ecu .made several times worked perfect . good luck
  6. #5
    Dec 2015
    thanks bro
