Results 1 to 7 of 7
    Apr 2019
    Question Mini ONE 1.6 r50 - mpps help needed
    Hello.
    I have MPPS and I can read my original file from the car fine.
    I've had the file tuned/modded, but when It comes writing the modded file back onto ecu, at 99% It's prompting me with "conditions not met".
    I'm able to flash my original file back on fine, but the tuned one is a no go...
    I'll attach both files.
    Thanks and I appreciate any help!
    a500tut's Avatar
    Jun 2017
    Belarus
    You have bad tuning and no checksum, try this and report!
    If I helped you, click thanks and reputation
  3. The Following User Says Thank You to a500tut For This Useful Post:
    samde95 (21st August, 2019)
    Apr 2019
    Quote Originally Posted by a500tut View Post
    typical ... but Thanks for that!
    Apr 2019
    What could be causing it to not start? Its writing onto the car fine but not starting.
    once the original file is back on its fine.
    NASTASE's Avatar
    ROMANIA
    Quote Originally Posted by samde95 View Post
    Hi mate,
    Your mod file have wrong checksum.No doubt.MPPS can't do the checksum in writing.
    a500tut user is right, no checksum and bad tune.
    you have modified "monitored maximum torque at clutch" map,"scaling factor for requested torque at clutch from driver"map, "limp home value of maf with throttle position diagnosis error" map,"setpoint mass air flow depending on slow torq"map,"catalyst exhaust gaz temperature in steady state"and so on.No fuel map touched, no spark map touched,nothing good in your mod file.If you write file provided by "a500tut" user car will start.Don't play with gasoline engine without knowledge, can melt pistons in a minute.
    Real engines don't need forced induction
    Who needs a turbo when you have a stupidly quick naturally aspirated engine?
    Apr 2019
    Quote Originally Posted by NASTASE View Post
    Hi mate,
    I bought that map too... won’t be going back there again.sent my original file to them to tune and that’s what I got back 🙃.
    I’ll use the one provided on here, but the one provided on here writes fine but won’t start?
    Thanks for the help!
    Apr 2019
    Hi, would you be able to checksum this new file for me?
