Results 1 to 11 of 11
    Default Peugeot 607 2.2 hdi edc15c2 3 plugs
    Hello can someone help me to immo off this ecu? i read eeprom and flash . thanks in advance
    does immo service tool works fine?
    systemlinux's Avatar
    Oct 2018
    CDK
    Try to attach vehicle info, photo of the PCM and you are reading to help faster.
    damaged eeprom reading.
    try this immo off
    Its a 607 2.2 hdi year 2001 .0281010975 9646466280
    Sep 2018
    Try it and report please
    Nov 2017
    ITALY
    Hi, your flash file ommo off. Try and report a feed. If it work fine, press thanks and reputation bottons. Bye
    Pass in PM.
    What´s the password?
    Nov 2017
    ITALY
    I sebd you a pass in your inbox message.
    Oct 2018
    CDK
    Quote Originally Posted by EGS View Post
    Pass in PM.
    What is the goal of entering passwords? if you want thanks or reputation it is because it worked.
    3 solutions were given to the partner and he has not informed, but I do not find it logical to put passwords to the archives.
    rafal's Avatar
    UK - PL
    Quote Originally Posted by systemlinux View Post
    Join Date Oct 2018
    Posts 82
    Thanks 45
    Thanked 1 Time in 1 Pos
    if you will be more active so you will know why pass..................
    need help
    now my goal is to buy xp-005
    who will help?
  11. The Following User Says Thank You to rafal For This Useful Post:
    danielif (22nd August, 2019)
  12. #11
    Nov 2017
    ITALY
    Quote Originally Posted by rafal View Post
    Join Date Oct 2018
    Posts 82
    Thanks 45
    it's true,
    the password is to prevent anyone from downloading the files, even those that are less active or that only use the forum for personal purposes. in my opinion.
  13. The Following User Says Thank You to EGS For This Useful Post:
    rafal (27th August, 2019)
