Results 1 to 13 of 13
    Apr 2018
    Default VW LUPO 3L 1.2 TDI Semi-automatic Transmission Problem
    Hi everyone, I have problem with Robot Transmission. When I drive on D or Manual mode, when car swich on 5-gear the clutch remains pressed and car doesnt want to running . I make diagnostic with launch and no have Fault in transmission. I replace Pressure Acumulator but without effect this problem remained. I make Adaptation as stated in Ross Tech for this Transmission but without effect problem remained. Please someone who know for this problem on this Semi-Automatic Transmission Help me Thank YOU!
    he clutch remains pressedthe clutch remains pressed
    dimitar's Avatar
    Try replacing the TCM
    50w Soldering Iron
    Chisel
    Sometimes Hammer
    Apr 2018
    okey thanks I will Try and report Thank you.
    Meat-Head's Avatar
    Sounds more like some kind of switch not sending signal back
    unlikky no teeth on 5th gear
    Apr 2018
    okey what is this swich?
    Meat-Head's Avatar
    RTFM
    ADVERTIDEMENT:-
    http://www.volkspage.net/technik/ssp/ssp/SSP_221.pdf
    download on to your own computer to preserve for futer generations
  7. The Following User Says Thank You to Meat-Head For This Useful Post:
    pfonseca (28th November, 2019)
    Oct 2018
    egypt
    What do you mean by semi automatic ? Dsg ? Which type of dsg ? Car doesn't want to running? Engine stop and stall or don't shift to 6th gear ? Give ECU and Tcm numbers as you see on scan tool
    wbr.
    Apr 2018
    I think this is not DSG. This is 5-speed Electronic Manual Transmission DS085. Car Swiches up to 4 gears extra but when swich 5 gear cluch remains pressed and i press accelerator pedal but car nothing run. The car dosent go off just goes by intertia. But after a while it includes 2 or 3 or 4 gears. Sorry for my english.
    remains pressed
  10. #9
    Oct 2018
    egypt
    I'm sorry .. I don't know about this gearbox
    wbr.
  11. #10
    Apr 2018
  12. #11
    Meat-Head's Avatar
    Post 6 is a link to how it works
  13. #12
    Apr 2018
    okey I saw this manual but I dont understand why swiches up to 4 gear whitout poblems and on 5 gear cluch is stuck but no have fault in TCM. I Think maybe problem is in TCM but i am not sure!
    switches
  14. #13
    u have problem with mechanism on gearbox , takie it to pieces and check slacks on mechanism
