Try replacing the TCM
Hi everyone, I have problem with Robot Transmission. When I drive on D or Manual mode, when car swich on 5-gear the clutch remains pressed and car doesnt want to running . I make diagnostic with launch and no have Fault in transmission. I replace Pressure Acumulator but without effect this problem remained. I make Adaptation as stated in Ross Tech for this Transmission but without effect problem remained. Please someone who know for this problem on this Semi-Automatic Transmission Help me Thank YOU!
he clutch remains pressedthe clutch remains pressed
okey thanks I will Try and report Thank you.
Sounds more like some kind of switch not sending signal back
unlikky no teeth on 5th gear
okey what is this swich?
RTFM
ADVERTIDEMENT:-
http://www.volkspage.net/technik/ssp/ssp/SSP_221.pdf
download on to your own computer to preserve for futer generations
pfonseca (28th November, 2019)
What do you mean by semi automatic ? Dsg ? Which type of dsg ? Car doesn't want to running? Engine stop and stall or don't shift to 6th gear ? Give ECU and Tcm numbers as you see on scan tool
wbr.
I think this is not DSG. This is 5-speed Electronic Manual Transmission DS085. Car Swiches up to 4 gears extra but when swich 5 gear cluch remains pressed and i press accelerator pedal but car nothing run. The car dosent go off just goes by intertia. But after a while it includes 2 or 3 or 4 gears. Sorry for my english.
remains pressed
I'm sorry .. I don't know about this gearbox
wbr.
IMG_20190822_162405.jpg this is TCU
Post 6 is a link to how it works
okey I saw this manual but I dont understand why swiches up to 4 gear whitout poblems and on 5 gear cluch is stuck but no have fault in TCM. I Think maybe problem is in TCM but i am not sure!
switches
u have problem with mechanism on gearbox , takie it to pieces and check slacks on mechanism
