Results 1 to 4 of 4
    Jul 2015
    Default Citroen C4 pPicasso EGR off needed EDC16C34
    I would be grateful, if somebody could fully disable the EGR valve without ESP and electric handbrake fault.
    The current faults of the ECU are P0409, P1459 and P0490.
    EDC16C34, 0 281 014 729, 96 656 744 80
    motocrazy's Avatar
    Dec 2010
    TR
    egr off dtc off test report please .. egr valve cable removed. pass pm
    Jul 2015
    It's not OK. If I leave the EGR valve connected, the ECU has no fault codes. However, the ESP and handbrake store CAN faults.
    If I disconnect the EGR valve, the ECU stores P2143. The fault codes in ESP and handbrake are also present.
    pike's Avatar
    Sep 2013
    Arrow Citroen C4 Picasso EGR off EDC16C34
    Hi.
    Here EGR off file, you can unplug valve.
  5. The Following 3 Users Say Thank You to pike For This Useful Post:
    gokart (24th August, 2019), konq100 (24th August, 2019), stanislav georgiev (25th August, 2019)
