Results 1 to 11 of 11
    May 2010
    Default Bmw X5 E70 grrr from automatic gearbox
    X5 3.0D E70 automatic gearbox
    Car come in because shut off in mountain.
    Twice.
    Car has been towed by other, maybe local mountain folk.
    Scan for fault: injector 4,5,6 activation
    So I put the car in NEUTRAL to lift it with the bridge and renew fuel filter.
    To replace filter you have to partially remove 3 underbody panels.
    Car has been in mountain so underbody has little rust in every screws
    and all the visible parts has been spray paint.
    After replace I start the engine with the car lifted and let it at idle
    for 15 minutes to check for leaks before closing the three panels.
    Then I shut off the engine with car lifted and in neutral.
    Then I returned the car to the floor and decided to go out.
    The car in the very first meters continuosly returned in P
    even if I select D or R.
    Also while running in the very first meter every now and then
    there was a grrr noise from the gearbox.
    Is it because the car has been in neutral with engine running?
    Is it beacuse battery was low on voltage (but crank with its battery )
    Is it because the car has been towed twice by mountain folk
    and maybe didn't use the appropriate procedure to tow it? (and damaged it)
    A scan with the tool give an error in the gear lever, but once erased the are no error.
    A test in the street show the car perform very well.
    Mar 2010
    Timisoara
    Transfer case problem
    Or check if oil level In gearbox is ok
    Check that all tires have the same hight value
    Regarding injector 4,5,6 activation for sure inj 5 or 6 when is hot bobine goes in short
    When engine stops and cannot be started and this error is displayed unplug inj 5 and try to start engine. If start this inj is in short, if not unplug inj 6 but reconnect inj 5, and so one
    Sent from my STK-LX1 using Tapatalk
  3. The Following 2 Users Say Thank You to clauberty For This Useful Post:
    alessioblaupunkt (28th August, 2019), autotrans (25th August, 2019)
    Meat-Head's Avatar
    Was it towed with a mountain goat or tow truck, all wheels off ground
    why not ask the owner full story.
    lot of bmw put box in park when door open, could it be something opened door mid flight and damaged box
  5. The Following User Says Thank You to Meat-Head For This Useful Post:
  6. #4
    Nice idea meaty but most trany's wont engage park or reverse, if the speed sensor reads more than 8mph approx.
  7. The Following User Says Thank You to autotrans For This Useful Post:
    Meat-Head (25th August, 2019)
  8. #5
    May 2010
    To change 6 injectors, what is the total time required?
    I ask this to prepare the invoice for the customer.
    It's ok the time given from the office software, if you have.
  9. #6
    Meat-Head's Avatar
    That’s all well and good but the office software time is when was new and was done 10 times
  10. #7
    Jul 2013
    yorkshire
    What was initial fault, or have i missed something.
  11. #8
    Meat-Head's Avatar
    Quote Originally Posted by autoden View Post
    Put that down as one of life’s misterys
  12. #9
    May 2010
    Initial fault is engine die, sporadic.
    Time required for 6 injectors is 4 hours, that's Alesso calculation if I have to
    remove intake manifold, many screws.
    Remove and insert.
    If:
    * intake manifold is ok
    * intake manifold sealant is ok
    * other things that could be wrong
    On Monday I will order the injectors.
  13. #10
    Jul 2013
    yorkshire
    You are changing injectors,,,, very brave move to make with no testing to prove or not prove. What will you do if its not the injectors. Who will pay? When customer comes, do you say "here is keys, its not fixed but you owe $1500". If you are sure its injectors, take them out and send for testing first.
  14. #11
    May 2010
    Car will be sent to scrapyard for these reason:
    * injectors bill too high to be accepted
    * has gearstick fault
    * has AC fault
    *has bought a dgiaghuar (same body style)
    ______
  15. The Following User Says Thank You to alessioblaupunkt For This Useful Post:
    Meat-Head (14th September, 2019)
