@vpanaiotov
нахрена?! learn to use google!
https://mibsolution.eu
user:guest
pass:guest
+M.I.B. - More Incredible Bash https://bit.ly/3nPIHl8
NOTE:
M.I.B. is running on Harman MHI2(Q) units (MIB 2.x) only.
CAUTION:
Ensure that a external power is connected to the car during any flash or programming process!
It is not recommended to flash with running engine!
Power failure during flasing/programming will brick your unit.
All you do and use at your own risk!
Prepare SD card:
Extract all files of the M.I.B. to the root directory of a clean SD-Card (FAT32 formatted is requirement!!!)
Patched IFS-stage2 images have to be placed on the SD card in the folder /patches
Pre-patched (CP, FEC and EL) ifs-root-stage2 images can be found for all recent MHI2 FW versions here: https://bit.ly/3nPIHl8
You only have to copy the folder(s) you need for your car(s) - e.g. /patches/MHI2_ER_SKG13_P4526_MU1440_PATCH
They are already prepared in the right way, so that the tool can use them right away
In case you want to use your own patches (not recommended) - ask us first to help you:
For each SW-train a seperate folder is needed e.g. /patches/MHI2_ER_SKG13_P4526_MU1440_PATCH
The folder has to contain the patched ifs-root-stage2 image with the following naming syntax:
"MU-version"-ifs-root-part2-"image start address in hex within RCC"-"image length in hex" --> e.g. MU1440-ifs-part2-0x00ba0000-1C06F300.ifs
image length is on byte 0x20 position 04-07 in little Endian of the original ifs-root-stage2 image (e.g. fresh from FW update)
NEW - GEM Method: use GEM
Insert the SD card into slot SD1 of your MHI2 unit.
Enter Engineering/Red Menu to start SW Update. Select UPDATE, select SD card, select "M.I.B. Launcher V1.0", START update.
Installtion of M.I.B. on your Unit will start. The unit will restart three time until update process is finished.
GEM will be activated as part of the installation.
SVM error has to be cleared via M.I.B. function in GEM after installation
Enter GEM on your unit and have FUN!
Select ==>>M.I.B.-More_Incredible_Bash<<==
"old" D-Link Method: Connect to MHI2 and start M.I.B.:
D-Link - e.g. DUB-E100 HW rev. D1 - USB-Ethernet adapter is required to connect to your MHI2 unit.
Use Putty/Kitty to connect via UART or Telnet (MIB IP:172.16.250.248) and login into RCC (recommended: port:123) or MMX (port:23).
Login and password for your units SW train has to be known: https://anonymousfiles.io/xzi8Nq2r/
Check your SW-train, a pre-patched ifs-root-stage2 has to be present within the folder /patches
Insert the SD card into slot SD1 of your MHI2 unit and login to the RCC shell:
# Mount SD card in slot SD1
mount -uw /net/mmx/fs/sda0/
# start M.I.B by typing
/net/mmx/fs/sda0/start
Default screen seize of Putty/Kitty is often too small to display the M.I.B. menu in full.
Increase the window seize manually.
You should see (a more colourful) menu with the following content:
__ __ ___ ___
| \/ | |_ _| | _ )
| |\/| | | | | _ \
|_| |_|ore|___|ncredible|___/ash - V2.6.x "Porsche Edition"
** 0 - Backup
Runs a full backup (RCC, MMX, EEPROM, ...) of your unit and places it into the folder /backup/"your hardware ID"
** 1 - VIM patch (199 km/h)
Writes custom Video In Motion (VIM) speed of 199 km/h (yes, too slow for German Autobahn) to your unit
Unit will automatically restart to save changes permanently
** 2 - VIM Original (6 km/h)
Writes factory default Video In Motion (VIM) speed to unit
** 3 - IFS-ROOT-Stage2 flash patched image
Will create a backup if it was not already created before
applies patched IFS Stage 2 image - containing patched MIBRoot - to the unit
Copy FEC and EL List to Unit - like option 5
** 4 - IFS-ROOT-Stage2 revert to Backup image
Applies original IFS Stage 2 image - containing original/stock MIBRoot - from your system backup to the unit
** 5 - Copy FEC and EL List to Unit
Copies ExceptionList.txt and/or FecContainer.fec placed within
e.g. /patches/MHI2_ER_SKG13_P4526_MU1440_PATCH to the unit
if no FEC and/or EL is inside /patch directory, files from /backup folder will be used
** 6 - Developer Menu activation
Developer Menu will be enabled - no need for VCP/VCDS or OBD11 ;)
** 7 - CarPlay & Android Auto activation
Coding adaption channels for CP & AA as well as USB with iPhone support
with this, all you need for Carplay is coded, you never need some other coding tools ;-)
** 8 - Ambient Light Buttons Original
When you see this, first take a look on https://www.glaskugelservice.de/codi...entbeleuchtung
it is some special coding only for Skoda Octavia 5E, yet!
** 9 - Ambient Light Buttons patch (first, set to Original)
** F - Fix SVM error
Fix SVM Fault on Unit
** G - Install M.I.B in GEM
Install M.I.B for use in GEM on Unit
** U - Mount USB writeable
makes USB devices writeable
** W - Mountpoints writeable
make some Mounts writeable on the unit
** O - Show OFFSET hashes
some Unit and flash informations, e.g. RCC Image address or image length
** R - Reboot Unit
restart the Unit
** C - cleanup Logs
delete all inside /log directory
** S - show Log (press Q for exit view)
show all our Logs from this Unit
** H - Help
this here...
** L - GPL License
please take a look and note our license
Patch Info:
All patches ifs-root-stage2 files in /patches/ (https://bit.ly/3nPIHl8) contain the following patches - all-in-one file:
CP - Component Protection removed
EL - ExceptionList.txt signature check removed (already prepared and part of each patch)
FEC - FECContainer.fec signature check removed
EL patch will re-enable the installation of MIB2Toolbox on latest FW version, as the removed signature check also applies to the POI upload process.
EL vs FEC:
It is recommended to use the EL patch over FEC.
ExceptionList.txt can be edited with any ASCII editor (Notepad++). Shorten the ExceptionList.txt to the FECs you need.
No need to change FECContainer.fec with WhatTheFec tool, therefore it will stay original on the unit.
In case of FW update - at dealer - no issues with illegal FECContainer and unusable unit.
Supporting Documents:
https://mibsolution.eu/#/1/9
user: guest
pass: guest
CONTACT:
mailto: Mr.MIBonk@gmail.com
Telegram Channel: https://t.me/joinchat/EHt4RRksHcMQk6Xi6tFaBw
Discord Server: https://discord.gg/YU3rjatWjT
Get in contact with us to get support and provide feedback about M.I.B.
