Hello. need help reading PIN anc CS from this ecu EDC17cp14
Results 1 to 7 of 7
    Jul 2010
    Downloads
    Uploads
    Default Hello. need help reading PIN anc CS from this ecu EDC17cp14
    Hello,
    my ecu went bad in i bough a used one including keys, immo, and autorisation lock for my audi a6 allroad 2010. Now the car starts but it activated CS lock.
    I tryed to read pin CS number but i keep getting 0's.
    Can somebody help me? plus i can read CONF DATA, external flash and internal flash. Which one contains PIN and CS data? is theere a way to mary the old gateway with the new ecu end immo and auth. lock?
    thanx Anej
    audi allroad zip is the old ecu dump
    Jan 2018
    72
    Downloads
    5
    Uploads
    hi try and read old and new ecu on bench bdm with ktag fgtech etc
    Jul 2010
    Downloads
    Uploads
    i am trying to. the new ecu is this one. but i keep getting 000 for PIN CS. Basically i can only go to AUDI where they will change with a new ecu new ezs reprogram all a small price of 13k euros ....
    Jul 2010
    Downloads
    Uploads
    anyway I am reading from bench. From OBD i cant even reach the ECU
    Feb 2019
    7
    Downloads
    Uploads
    original
    VIN:WAUZZZ4F9BN022310
    IMMO ID:No Immo ID
    CS:618ACD3038FC8A
    MAC:59BDB8D8
    Config:37E554
    PIN:19070
    new
    VIN:WAUZZZ4F9BN017673
    IMMO ID:No Immo ID
    CS:184F513E309E00
    MAC:51D31E0F
    Config:37E554
    PIN:54045
    Jul 2010
    Downloads
    Uploads
    The PIN doesnt work i tested both of them but they are not working plus it asks me of power class ? What am I doung wrong?
    Feb 2019
    7
    Downloads
    Uploads
    Quote Originally Posted by afric View Post
    the data i have posted is 100% correct what i can see dont know what you are doing
    and depend on tool which you are using
    + find out where is thanks and reputation buttons after some one help you you can press it
