Results 1 to 11 of 11
    Aug 2019
    The Netherlands
    Default Ford Focus 1.6 TDCI MK3 EDC17C10 CAN Need help with file check
    Hi guys,
    I'm new here and also new in the tuning world.
    Excuse me if I'm posting this in the wrong section.
    I need help with reading my original ECU file.
    Can someone check if the file is correct and does not contain any errors?
    A little background;
    A bought myself an Chinese Kess v2 Clone. It took me almost 3 weeks to get it working.
    I had an issue with reading my ECU, every time i got an ''checksum error''.
    Yesterday I updated my DLL files and today I managed to read the ECU without any error's.
    But now when I try to check the file with WINOLS or ECU Titanium all I can see is that the file is empty.
    Am I doing something wrong or is my Kess just not working properly?
    Aug 2008
    LV
    for sure its not empty
  3. The Following User Says Thank You to fricker For This Useful Post:
    bws723 (25th August, 2019)
    Aug 2019
    The Netherlands
    Quote Originally Posted by fricker View Post
    Thank you for your fast response.
    So does this mean that I can use the file to buy an stage 1 file from those oo so many file service tuners?
    macako6's Avatar
    Mar 2015
    yes, you can use it freely. Your tuner will explain the next steps
  6. The Following User Says Thank You to macako6 For This Useful Post:
    auto techniek's Avatar
    Mar 2017
    Quote Originally Posted by bws723 View Post
    Hi guys,
    Can you share how you solved this probleem.
    I ve the same.
  8. #6
    Aug 2019
    The Netherlands
    Quote Originally Posted by auto techniek View Post
    I ve the same.
    I replaced the DLL's from the attached file.
    Please let me know if it works for you too.
  9. The Following 2 Users Say Thank You to bws723 For This Useful Post:
    auto techniek (9th September, 2019), bendy (12th March, 2022)
  10. #7
    Mar 2017
    Did you succeed writing back the file to ECU?
  11. #8
    Aug 2019
    The Netherlands
    Yes, I can read and write without any problems.
  12. #9
    Mar 2017
    I did replace dll map and software works great.
    Did modify the ECU edc17c10 software with kess and succeeded.
  13. #10
    Aug 2019
    The Netherlands
    Nice! Glad to hear that it worked for you too.
  14. #11
    Aug 2019
    The Netherlands
    Hi guys,
    Im back with more question. Can someone please check if the DPF is deleted in my file?
    Yesterday i found out that 2 of the 3 cables of the DPF were dissconnected. I bought the car 2 months ago, and have black smoke.
    So i think that th old owner scammed me...
