Results 1 to 7 of 7
    Oct 2018
    Earth
    Default BMW E39 528i M52B28 Tune request
    Hello, i need tune for m52b28 - standard, i need hardcut rev limiter 7000rpm and some more power.
    Transmission: Manual
    ECU: Siemens MS41.0
    ECU number: 5WK90322 1429861
    i'm attaching ori file, taken with Kess V2.
    a500tut's Avatar
    Jun 2017
    Belarus
    Quote Originally Posted by khaos87 View Post
    ECU: Siemens MS41.0
    Hello, try and report!
    If I helped you, click thanks and reputation
  3. The Following User Says Thank You to a500tut For This Useful Post:
    cratemaster (14th September, 2023)
    Feb 2018
    can someone pls add pop and bang on a bmw e39 523i and maybe more hp pls
    https://mega.nz/#!gOQh2QTb!PbBMiYmE-...UmEEExtSNJa0n8
    May 2017
    You be here sind nearly 2 years and got 7 posts...
    are you only here to request files?
    Apr 2016
    It's the partial coma team...
    Mar 2024
    E39 528i simens 41.0 throttle response remap?
    May 2017
    There is no throttle response map... use brain its mechanical throttle body... you just can map some stuff for the down reving, lag.
