Lambda1 (28th August, 2019)
Okay can U maybe little explain more... got xprog but never work with em, I also didnt install xD... but will do now.
Okay I saw there is only CAS 4 moduls listed?
need to read eprom and flash seperat?
MCU > 9S12 Secured > bottom of list 9S12 EEPROM then 9212 FLASH
Merci my friend. For this CAS reads Iam absolutly beginner.
Also thanks. Will test with xprog first.
After you make your connections to CAS and your xprog with BDM adapter you make your selection like below. Do EEPROM first and save it. Then do the same for FLASH. Open eeprom file in your key maker and select a UNUSED spot. DO NOT write file back even if it tells you to or you will need to resync CAS>DME most likely.
because of cant get xprog for working I bought R270 and use connection from rar (above).
But now problem is if I choose 2K79X ... and check for wire connection it search and search and search... if I check "wire pin state..." I search but end with error.
Solution?
Ps: In mine connection diagramm there is one more cable than in above, but also test and didnt works.
R270 does not always work. You must use a good clone of Xprog or R260 Red clone that is always 100 percent
Press Thanks and Reputation
Mhm, dont know about R260... this R270 has red board. But it is cheap 50-60 dollar grap.
Maybe somebody get good source for buying a working one?
Okay will get such a thing.... thanks
Okay, there are so freaking much things out there for this jobs :O.
Thinked xprog was best choice... but cant get em work, bought R270 but also dont work fine xD, maybe the next will work and I can clone this cas.
Thats why i prefer solderjobs xD
