Results 1 to 3 of 3
    Aug 2010
    Exclamation Ford Transit 2,2 D SID 208 need change flash to 140HPh
    Hi M8
    please need help for this job
    i have exact to same ECU SID 208
    The org is total dad. Customor by a set of this ECU, Key and BCM. BUR not the same power clas
    the car have dtc and only run 100 km/h
    He change the ECU from a 101 HP but the engine is a 140 HP
    so i read complete the new used ECU
    SID 208
    S180145002 A
    4VFC
    CC11-12A650-AC
    8 all this number are 1:1 of the org ECU
    and need a flash file for this ECU with 140 HP
    any help please
    Thx in advance
    Aug 2010
    any help please
    Not possible to use IDS and reprogram ECU?
    I ask becuase I many times reprog ECU with IDS. When IDS start and ident ECU than ask user "The ECU data is correct?" Than You answer "NO" and put correct calibration data.
    This way not work to SID206? Too new ECU?
