Results 1 to 15 of 24
    Feb 2016
    Default Mitsubishi eclipse cross clear crash 0285013178
    Hello
    Please clear crash
    Mitsubishi
    Eclipse cross
    2018
    0285013178
    bq101
    8635a423
    Feb 2016
    someone will try a proven solution
    lucic66's Avatar
    Aug 2015
    Wat eep...or.....
    Quote Originally Posted by ZIOMAL4340 View Post
    Feb 2016
    does anyone have a proven solution?
    Jan 2018
    Interested as well
    Mar 2018
    Default please give me a solution.
    Please help with crash
    Dec 2017
    6 POST FROM 2018 WHER ARE YOU?
    superjet's Avatar
    Aug 2018
    Quote Originally Posted by nbologov1 View Post
    Test and report back.
    pass pm.
    Mar 2018
    Thanks, but I solved the problem!!! I have the solution.
    Apr 2012
    looking for solution to this same module mitsubishi 8635a423 eerpom 95128
    superjet's Avatar
    Aug 2018
    Quote Originally Posted by mkopytekchi89 View Post
    test and report back.
    pm
  12. The Following 2 Users Say Thank You to superjet For This Useful Post:
    JERIA (6th July, 2023), mkopytekchi89 (20th October, 2020)
  13. #12
    Apr 2012
    Tested file and works without having to set seat weight or do anything extra. Thank You SuperJet for your help. Did you compare from older mitsu or other style of newer mitsu? I will use your file to compare with newer modules if i need to clear.
  14. #13
    superjet's Avatar
    Aug 2018
    i compare 8635A423 tested file
  15. #14
    Dec 2011
    Ukraine
    Hello, please help me to clear the crash. 8635а423
  16. #15
    Apr 2018
    Overseas
    Hi,here is your clear file
  17. The Following User Says Thank You to belazas4 For This Useful Post:
    Sania (31st January, 2021)
