Results 1 to 15 of 17
    venceslau's Avatar
    Dec 2018
    North America
    Default KTAG Checksum Error When Saving Backup
    Can someone please tell me if there is anything wrong with this ktag clone backup dump?
    I keep getting checksum error and not sure what to do.
    Thanks in advance
    Attachment 646923
    DK Veteran daniel guerra's Avatar
    Picture is very small, can you upload a picture with higher resolution?
    Which KTAG version are you using?
  3. The Following User Says Thank You to daniel guerra For This Useful Post:
    venceslau (31st August, 2019)
    venceslau's Avatar
    Dec 2018
    North America
    Quote Originally Posted by daniel guerra View Post
    Hi, I'm using KTAG Clone. Sticker on it says (HW 7.020) and (SW 2.23).
    The Ksuite I'm using for KTAG is 2.25 however (not sure if that makes a difference).
    I uploaded the picture as a zip because forum keeps resizing image for some reason.
    The message says: "Checksum error, send the software vendor the backup file"
    Error only pops up after I type in filename and click save.
    UPDATE: I found a download of Ksuite 2.23 online and installed and read again and getting the same message.
    Also compared dump to the one I obtained from 2.25 and they match.
    vitaliyl's Avatar
    Aug 2018
    Ukraine
    install MICROSOFT VISUAL C++ 2005 the problem will be solved
    Don't forget hit thank button if i helped.
  6. The Following 3 Users Say Thank You to vitaliyl For This Useful Post:
    datapage (20th April, 2021), maajkii (31st August, 2019), venceslau (31st August, 2019)
    venceslau's Avatar
    Dec 2018
    North America
    Quote Originally Posted by vitaliyl View Post
    Thanks for your suggestion, I do have MS Visual C++ 2005 installed but the problem persists.
    I will try with a different computer.
  8. #6
    venceslau's Avatar
    Dec 2018
    North America
    I tried on different computer and made sure MS Visual C++ 2005 but getting the same error.
    Let me clarify that the procedure reaches 100%, then asks me for filename to save to, after I click save I get this error. I've read many threads with similar problem but it happens at 99% so I wonder if the dump is OK maybe?
    Sent from my A0001 using Tapatalk
  9. #7
    vitaliyl's Avatar
    Aug 2018
    Ukraine
    try 1. install original k-suite software 2. del folder ksuite ori (c:\\KSuite) 3. put folder (KSuite clone) instead ori ksuite
  10. The Following User Says Thank You to vitaliyl For This Useful Post:
  11. #8
    venceslau's Avatar
    Dec 2018
    North America
    Thanks again, that is how I installed it. I gave up on Ktag, trying to clone using KessV2 instead, hopefully it works. Otherwise I don't know what else to do.
  12. #9
    venceslau's Avatar
    Dec 2018
    North America
    I think I understand what is going on. I found a blog post saying Continental Mss60 are not cloneable and must be matched instead so I think I will go that route instead. Thanks for your help!
  13. #10
    Quote Originally Posted by venceslau View Post
    I'm not sure about not being able to clone the tool, at least you should be able to read the file, and you're not able to. Try to use Ksuite 2.23 instead of 2.25.
    It happen to me with an EDC16 and I've managed to read with galletto v54.
  14. #11
    Mar 2016
    Bosna i Hercegovina
    I had same issue with edc16 checksum error after saving backup turned out to be corrupted flash !(hope this helps someone if find since its old thread)
  15. #12
    May 2017
    Only earlier MSS60 can be cloned! Later models one processor side is bloecked.
  16. #13
    GEORGIA , TBILISI
    Hi, and what is the way out of this? I tried to update my MSS60 using VINFKFP and the process did not complete until the end, now DME does not get in comunication ! Where can I get a full dump for DME recovery? if I have a full dump, can I restore it with K-TAG?
  17. #14
    Jan 2020
    france
    Quote Originally Posted by GIODIAGNOS View Post
    Does the dme respond at all in tool32 or inpa or WinKFP? If so try reflashing with WinKFP. I’d just use the update function - it’ll figure out the VIN and such from there on its own.
  18. The Following User Says Thank You to ombre57 For This Useful Post:
    amd57 (10th January, 2022)
  19. #15
    GEORGIA , TBILISI
    The fact of the matter is that DME does not react and it does not connect! Brick!
