Page 2 of 2 FirstFirst 12
Results 16 to 24 of 24
  1. #16
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Quote Originally Posted by leotdx View Post
    Try another cable. My carprog reads that ecu . Done that.
    Reads on car by obd?
  2. #17
    pioneer427's Avatar
    Feb 2017
    Belarus
    Quote Originally Posted by Panathaole View Post
    Yes. My Carprog read and write this ECU by OBD
  3. #18
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Quote Originally Posted by pioneer427 View Post
    That's very good news, so you can help us to improve our tools if it needs....
  4. #19
    pioneer427's Avatar
    Feb 2017
    Belarus
    Have you replaced the logic chips 74HC125D? Tested with an A1 adapter?
  5. #20
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Yes, I had replace them with m, I manage to read all the eeprom that I try on it... Adapter n9 can't detect any error...
    Are you rework cp by yourself?
  6. #21
    pioneer427's Avatar
    Feb 2017
    Belarus
    I changed the logic chips to Texas Instruments 74HC125D. In a1 adapter, I swapped resistors with capacitors. Maybe you have a problem in the firmware and LIB file? I can post my program firmware and lib
  7. #22
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    My carprog work good....
    My only issue is the a1 cable, I test it and I have no connection with A1 adapter, so I thing my cable is problematic.... I had replace the 2515 chip with new branded, but nothing....
    If you can, can take a pic of your a1 PCB?
  8. #23
    pioneer427's Avatar
    Feb 2017
    Belarus
    Here is a photo
  9. The Following 3 Users Say Thank You to pioneer427 For This Useful Post:
    ilkovelichkov (17th November, 2023), juanes 3 (11th August, 2020), Panathaole (19th October, 2019)
  10. #24
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    I can't see any difference between yours and mine pcb....
    Maybe I have fault 2515?
    It's brand new .... I use back the old one and test again....
    Thank you...
