Results 1 to 4 of 4
    Jun 2011
    Northamptonshire, UK
    Default Chevrolet Cruse 2011 Wiring Diagrams
    Does Anyone have a lighting wiring diagram for a uk Chevrolet Cruse 2011.
    I have no position lamps working, Brake Lamps or Rear Fog Lamps.
    Also The cigarette lighter isn't working either, (there is no power to the fuse).
    Thanks in advance
    Nik
    Sep 2019
    [CITAÇÃO = Music73; 3664753] Oi
    Alguém tem um diagrama de fiação de iluminação para um Chevrolet Cruse do Reino Unido 2011.
    Não possui lâmpadas de posição ativada, lâmpadas de freio ou luzes de nevoeiro traseiras.
    O isqueiro também não está funcionando (não há energia não fusível).
    Agradecemos antecipadamente
    Nik [/ QUOTE]
  3. The Following 2 Users Say Thank You to jadisson For This Useful Post:
    Alleg Marouane (18th February, 2020), Music73 (8th September, 2019)
    narkeleptk's Avatar
    May 2017
    USA
    Quote Originally Posted by Music73 View Post
    Thanks in advance
    Nik
    These have a lot of problems with BCM, sounds like it may be worth checking out considering your symptoms.
    Jun 2011
    Suspect bcm but was hoping for a diagram so I could check properly..
    Sent from my iPad using Tapatalk Pro
