We can't see both labels but if they are same post the dump of the Eeprom of the spare and we'll try to it make off. Then you'll enter injectors codes into new one.
Greetings,
Greetings,
I've uploaded two photos. The second one clearly shows the numbers.
Here are the written ones:
My original ECU has the following numbers:
0 281 013 872
9653958980
1039S20163
96 648 437 80
Тhe computer i bought from another car has the following numbers:
0 281 011 560
9653958980
1039S09388
96 595 966 80
Both are EDC16C34.
Is it enough to:
1. BDM read the EEPROM of the spare one, then remove IMMO and write back the new EEPROM.
2. Program my injector codes with some DIAG.
Read by bdm all and write bdm all. Its enaugh.
Louislesinge (7th September, 2019), SoftDev (9th September, 2019)
Sorry but how you understand they have same hardware? Is this number 9653958980 important?
We know it because of the Bosch reference 0 281 XXX XXX they both can be converted into an hardware family: EDC16C34-4.11. This can be found using Bosch Esitronic software.
Or have a look here:
https://www.digital-kaos.co.uk/forum...abase-software
Something else, you can begin to press "thanks" button under avatars of people that try to help you, it's easy and free.
Thanks here and thanks under avatar.
