Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
  1. #16
    How to do this unlock via vag can pro?
  2. #17
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Quote Originally Posted by ptikkala View Post
    not possible by VAG CAN PRO...
    here nofication from manufacture site...
    but youu could use google to get this news...
  3. #18
    Spain
    Quote Originally Posted by 3inferno3 View Post
    Need to be opened too
    You´re wrong M8, with genuine tools not need to open . no need to unlock, all can be done by eobd connector.
    Regards.
    Chiptuning file services ,custom remaps, inmo off, egr off, dpf off, adblue off, flaps off, tva off, lambda off, speed limit, selective dtc´s deleting ,etc.
    Worldwide assistance.
    All brands, All vehicles, All files.
  4. #19
    Oct 2019
    Autotuner can unlock this ecu on bench but without opening.
    After that you can read and write even with China kess.
    Send it to get it unlocked will be the easiest option for you
  5. #20
    galiza's Avatar
    Jun 2011
    Kess 3.0 or higher can do it without open ecu (tested several times with slave kess).
    It is a strange situation because you can unlock with kess 3.0, read and write without problem but kess 2.08 clone keep saying the ecu is locked.
    It is better to arrive 10 minutes early, than to be bored all the way.
