I tried t7sute,but i do not believe in this progrom.
Someone ti help with this ecu.
IF I HELP YOU PUSH THANKS AND REP BUTTON
here stage 1 2.3t try and report make sure you checksum before write
what are you using to compare?
do you get checksums with winols when you load it in?
T7suite works ok on trionic t7
I use it to make immo off an ecu couple of weeks ago....
familiozo (11th September, 2019)
The file is different if winols can't checksum it can't tell you if it's different when it is
Your file without crc
Let make your tool the checksum!
Sedat Garip
Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
Diesel + petrol All cars
Manual Adblue dpf egr Opf tested working solutions
Belgium
With Kind Regards,
Don't forget hit thank button if i helped.
T7suite recognize the file?
