Results 1 to 15 of 19
    Team dz's Avatar
    Apr 2017
    ALGERIA
    Default nissan x-trail T31 P 0611
    HI dk
    good evening friends.
    The problem started when you changed the battery
    I know the car is running but the engine torque 1500 rmp
    Fault code P0611 injection adjustment valve (present), I tried to enter the codes of the 4 injectors with launch X431 and Acita multidiag but no resulat, the jecteurd code always remains AAAAAAA on the 4 injectors
    I need virgin eeprom 95320 if Tested .
    code injectors
    injectors 01:7HZR2WF
    injectors 02:7IRV3VF
    injectors 03:7AHV1IF
    injectors 04:6SG81WF
    eeprom 95320
    0281013874 23710 JG78B
    hw:8200000001
    sw:1037387003
    sw upg:JH12A
    Thanks for your help.
    DPF / FAP / EGR / SCR / NOx / TVA FLAP .. etc
    Do not forget to press the button thanks and reputation
    # Algerian #
    Team dz's Avatar
    Apr 2017
    ALGERIA
    any help !
    # Algerian #
    Team dz's Avatar
    Apr 2017
    ALGERIA
    You have successfully resolved the problem
    # Algerian #
    Team dz's Avatar
    Apr 2017
    ALGERIA
    And everything is perfect !
    # Algerian #
  5. The Following 3 Users Say Thank You to Team dz For This Useful Post:
    ecufix (30th October, 2019), miz (6th September, 2023), patpuku (18th September, 2019)
    Sep 2019
    Quote Originally Posted by Team dz View Post
    Dear Sir, I got the same problem with the injectors coding can not put the new code even use the consult III. Could you please explain how to fix this problem. Thank you so much. PAT
    Feb 2018
    Default HI Please help i have a problem in Injector code Injector code AAAAAAA NISSAN X TRAIL
    0 281 014 362
    Dec 2018
    [QUOTE = mohssin BANZ; 3675865]
    Код форсунки AAAAAAA
    0 281 014 362 [/ QUOTE]
    Do not repair your smartphone. take a crystal ball
    Team dz's Avatar
    Apr 2017
    ALGERIA
    Whoever wants the solution I will help him immediately
    Send me in pm
    # Algerian #
  10. The Following 2 Users Say Thank You to Team dz For This Useful Post:
    Catalizator (21st September, 2019), hadrian (30th March, 2021)
  11. #9
    Feb 2018
    Default Please help
    code injectors
  12. #10
    Feb 2018
    HI Password
  13. #11
    Team dz's Avatar
    Apr 2017
    ALGERIA
    Mr mohssin BANZ Depend on copying and pasting and want help
    Something great to like you
    # Algerian #
  14. The Following 3 Users Say Thank You to Team dz For This Useful Post:
    dasboard3 (11th December, 2019), ecufix (30th October, 2019), rdu04 (11th January, 2022)
  15. #12
    moky's Avatar
    Behind you
    hi
    same problem for me P0611 on qashqai.. team dz or other person you can help please? I sent you pm
    many thanks
  16. #13
    galaxy0634's Avatar
    Jan 2018
    Namek planet
    Hi friends please i have same probleme nissan x trail always injector is AAAAAAA i can,t programme it with tool thanks in advance
    *I helped*push thanks button
  17. #14
    dasboard3's Avatar
    hi
    i need pass proplem equal
  18. #15
    Member hadrian's Avatar
    Thanks again @Team dz. File is ok, car start.
