Ford S-max Bosch 0285013766 E1GT 14B321 BE
Results 1 to 9 of 9
    Sep 2015
    34
    Downloads
    7
    Uploads
    Default Ford S-max Bosch 0285013766 E1GT 14B321 BE
    I am looking for crash reset on Ford RCM module
    Car: Ford S-max 2016
    Bosch: 0285013766
    FORD: E1GT 14B321 BE
    Memory: 95640
    AB4S's Avatar
    Jan 2014
    Sheffield, UK
    22
    Downloads
    Uploads
    Your cleared file.
    Please report
    Don't forget to push the thank+reputation buttons if i helped.
    Sep 2015
    34
    Downloads
    7
    Uploads
    Quote Originally Posted by AB4S View Post
    Your cleared file.
    Please report
    Thank you for your effort but file doesn't work
    Sep 2015
    34
    Downloads
    7
    Uploads
    Still looking
    AB4S's Avatar
    Jan 2014
    Sheffield, UK
    22
    Downloads
    Uploads
    Quote Originally Posted by Thinkpad88 View Post
    Hi, what faults remain? Tested solution :/
    Sep 2015
    34
    Downloads
    7
    Uploads
    A lot of errors, including internal module fault and ABS is triggering fault that faulty values are received from RCM module.
    AB4S's Avatar
    Jan 2014
    Sheffield, UK
    22
    Downloads
    Uploads
    I think your dump is not correct, looks completely different to the 4 dump crash files i have with this part number. Try this dump from another vehicle cleared.
    Best Regards
    Sep 2015
    34
    Downloads
    7
    Uploads
    I tested also this file and its not OK.
    With ori file I only had crash data DTC.
    With this last one these come up:
    ABS: U0452, C0062
    RCM: B140E, B140F, U0253, U2300, U3000, C0063
    File not OK.
    Sep 2015
    34
    Downloads
    7
    Uploads
    Is it possible that eeprom and flash are locked together, so even if eeprom is swaped from other module with same HW Bosch & Ford number it will not work?
    I have tried a lot of files, always similar DTC's, originaly car had 1 crash data DTC. I also chenged VIN in dump that is from other car and reported working but still nothing.
    ABS is trigering invalid data received from airbag module - RCM.
    RCM is reporting U3000:49-AF internal module failure
