Results 1 to 10 of 10
    Sep 2015
    Default Ford S-max Bosch 0285013766 E1GT 14B321 BE
    I am looking for crash reset on Ford RCM module
    Car: Ford S-max 2016
    Bosch: 0285013766
    FORD: E1GT 14B321 BE
    Memory: 95640
    AB4S's Avatar
    Jan 2014
    Sheffield, UK
    Your cleared file.
    Please report
    Sep 2015
    Quote Originally Posted by AB4S View Post
    Your cleared file.
    Please report
    Thank you for your effort but file doesn't work
    Sep 2015
    Still looking
    AB4S's Avatar
    Jan 2014
    Sheffield, UK
    Quote Originally Posted by Thinkpad88 View Post
    Hi, what faults remain? Tested solution :/
    Sep 2015
    A lot of errors, including internal module fault and ABS is triggering fault that faulty values are received from RCM module.
    AB4S's Avatar
    Jan 2014
    Sheffield, UK
    I think your dump is not correct, looks completely different to the 4 dump crash files i have with this part number. Try this dump from another vehicle cleared.
    Best Regards
    Sep 2015
    I tested also this file and its not OK.
    With ori file I only had crash data DTC.
    With this last one these come up:
    ABS: U0452, C0062
    RCM: B140E, B140F, U0253, U2300, U3000, C0063
    File not OK.
    Sep 2015
    Is it possible that eeprom and flash are locked together, so even if eeprom is swaped from other module with same HW Bosch & Ford number it will not work?
    I have tried a lot of files, always similar DTC's, originaly car had 1 crash data DTC. I also chenged VIN in dump that is from other car and reported working but still nothing.
    ABS is trigering invalid data received from airbag module - RCM.
    RCM is reporting U3000:49-AF internal module failure
    Mar 2016
    Hello Friend. Did you fix the problem with the RCM Ford Smax driver? I have a similar case with you.
