Results 1 to 5 of 5
    May 2017
    Espaņa
    Default MARELLI IAW4MV.DS IMMO OFF
    Hi all, i need do immooff for seat leon 1.6i with iaw4mv.ds
    if anyone can remove immo i appreciate it. Thanks
    pioneer427's Avatar
    Feb 2017
    Belarus
    Your immo off
    pass in pm
  3. The Following User Says Thank You to pioneer427 For This Useful Post:
    hrmotorsport (11th September, 2019)
    May 2017
    Espaņa
    do you know pin of kline to check in bench this ecu?
    pioneer427's Avatar
    Feb 2017
    Belarus
    Pinout this ecu
  6. The Following User Says Thank You to pioneer427 For This Useful Post:
    May 2017
    Espaņa
    i already tested same pins but i cant connect, may be is needed put 120ohm between can h and l ?
