Results 1 to 4 of 4
    Mar 2017
    Default Audi a4 b7 1.9 PD TDI BKE engine 115
    Hello guys, a have a problem with this car.
    It is equipped with EDC16U31 ecu ( 03G 906 016 FE ) SW : 390131
    And with a modified file it gives an error P0602-000 - Programming error and the glow plugs are flashing. The cars runs perfect with the modded file. With the ori file this DTC is not recorded.
    What seems to be the problem, can someone explain, help?
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    Just delete this foult in software
    Chiptunning / EGR / DPF / FAP / DTC / FLAPS / Adblue / ETC.... CUSTOM SERVICE / FILE SERVICE / 24/7 Support
    Nov 2017
    ITALY
    The file has been changed for me. there are maps copied from some other file for sure. Many wrong changes. put the file ori, what you read and see if it still gives you the error.
    Mar 2017
    Quote Originally Posted by EGS View Post
    With the ori file there is no problem, with the modded file there is no problem too exept the flashing glow plug light and DTC p0602. The file has been made from the original of the car
