Here mate try and report
pass in pm
pass in pm
psatter (18th September, 2019)
Thanks, I will do this
I get still P2080.
Maybe the sensor is defect.
Is it possible to turn off this dtc?
Try it now same pass
after testing some weeks, I get "P2455-00 differential pressure sensor voltage too high" and at some time "P1260: exhaust gas temperature particle filter - signal incorrect/implausible"
Also in the instrument cluster der dpf lamp is on and at display it shows "particle filter ist blocked..."
Is it possible to turn off this dtcīs?
Thanks a lot for help.
dtc off don't solve this problem
needed complete dpf to be done
Proffesional ECU & TCU Tuning
Petrol and Diesel Engines
File Service
could you help me to solve the problem?
