Results 1 to 11 of 11
    EU
    Default Ford Focus Cabrio 2.0 TDCI dpf off
    Hi everybody,
    can someone help me with good dpf off to this car ?
    Ford Focus Cabrio 2.0TDCI SID803A SW: 10157082AA
    Thanks in advance.
    Nov 2017
    ITALY
    Your file. Pass in PM.
  3. The Following User Says Thank You to EGS For This Useful Post:
    ollync (17th September, 2019)
    EU
    I still get dpf dtc but i think it is because the dpf temp sensor is damaged .
    Sent from my iPhone using Tapatalk Pro
    Nov 2017
    ITALY
    Write me the dtc code and tell me if the car is in recovery mode.
    EU
    I get P2002 - Diesel Particulate Filter Efficiency Below Threshold Bank 1 and
    P141E - Catalyst Temp sensor 1/2 correlation.
    By recovery mode do you mean if the car is trying to regenerate dpf? - I don’t know if is trying to regenerate , for now i can’t drive the car because it has no license plate.
    EU
    Anybody can help me out with this?
    Nov 2017
    ITALY
    Your file, pass is same. Bye.
  9. The Following User Says Thank You to EGS For This Useful Post:
    ollync (27th September, 2019)
  10. #8
    EU
    Thanks again but not working.
    Car has no dtc but won‘t rev more than 2000 rpm when driving and has no power.
  11. #9
    EU
    Problem solved
  12. #10
    Aug 2010
    How did you solve the problem? I have same isue.
  13. #11
    EU
    If i correctly remember, i reset all dpf values and unplugged sensors, temp and pressure .
