Results 1 to 12 of 12
    Member maxbis94's Avatar
    FRANCE
    Thumbs up Airbag infinity Q50 25348 4GN0A 0 285 012 358
    I need clear crash for Pedestrian Protection system 253484GN0A 0 285 012 358.
    eeprom:95640
    Thanks in advance.
    Best regards
  2. The Following User Says Thank You to maxbis94 For This Useful Post:
    ktome (29th November, 2019)
  3. #2
    robert1232's Avatar
    Dec 2010
    Ireland ;)
    Default here is
    Posts85
    Thanks1
    help too som friend
    and press thanks if help
    thanks+reput
    pass
    raport
    PRESS THANKS AND REPUTATIONS (STAR) BUTTON
    I don't give others the password to the file. I'll send my file and I'll try to make it
  4. The Following 5 Users Say Thank You to robert1232 For This Useful Post:
    JAN07 (13th August, 2021), Jarekw1 (8th November, 2019), ktome (29th November, 2019), maxbis94 (13th September, 2019), superjet (14th September, 2019)
  5. #3
    FRANCE
    Thank you Robert
    Your file work perfect.
    BR
  6. The Following User Says Thank You to maxbis94 For This Useful Post:
    robert1232 (9th November, 2019)
  7. #4
    Nov 2010
    hi , can sameone help clear crash
    0285012358 25348 4gn0a pop up hood module
    eprom 95640
    thanks inadvance
  8. #5
    robert1232's Avatar
    Dec 2010
    Ireland ;)
    BAD READ MY FRIEND
    Quote Originally Posted by Jarekw1 View Post
    eprom 95640
    thanks inadvance
  9. #6
    Nov 2010
    read eprom as st 95640
  10. The Following User Says Thank You to Jarekw1 For This Useful Post:
    ktome (4th June, 2020)
  11. #7
    robert1232's Avatar
    Dec 2010
    Ireland ;)
    Default here is your file
    thanks+reput
    after pass in pm
    raport
  12. The Following User Says Thank You to robert1232 For This Useful Post:
    Jarekw1 (9th November, 2019)
  13. #8
    Nov 2010
    today i try in car and report
  14. The Following User Says Thank You to Jarekw1 For This Useful Post:
  15. #9
    Senior Member buul's Avatar
    Try this file
  16. The Following 3 Users Say Thank You to buul For This Useful Post:
    Ginocar (15th September, 2020), Jarekw1 (12th November, 2019), ktome (29th November, 2019)
  17. #10
    Nov 2010
    Quote Originally Posted by buul View Post
    Try this file
    not work ,
    have dtc:
    b26ac pop up hood ecu ,unit malfunction.
  18. #11
    Nov 2010
    solved problem with this file:
  19. The Following 6 Users Say Thank You to Jarekw1 For This Useful Post:
    buul (22nd November, 2019), jupulino (20th July, 2023), ktome (29th November, 2019), line44 (22nd May, 2023), Safety (1st April, 2021), SergeyIg (23rd November, 2021)
  20. #12
    May 2022
    With the amount of Thanks this has received: Is this universal, is it safe to write the same file to my Eeprom to clear it as well, or does my specific Version need to be modified?
