Results 1 to 15 of 15
    gueswhat's Avatar
    Nov 2016
    World wide
    Default Vespa 300cc HPE 2019 key lost help needed
    hello friends
    i have a vespa 300 newest hpe
    FULLY lcd dash model 2019
    ecu :CM291701 (32M4G1.F01)
    i wanted to read this ecu but by pins like the old ecu but i can read this because this is the newest model
    and my tool is not support this ecu
    but i have done one earlly model hpe whit the same dash as 2018 model abs NOT LCD DASH but hpe this was also whit same new ecu
    but i have find a solution for start them but
    on this new model it dont work
    so this one i most open up to see where mcu is DOES anyone already open this ecu or dig in it ?
    does someone done this ecu already
    thank u friends
    i have upload some picture and also the old ecu to you to see what is change on this model ecu
  2. The Following User Says Thank You to gueswhat For This Useful Post:
    clubmanza (22nd January, 2024)
  3. #2
    Feb 2016
    If you can not solve this now another solution is to put a older gts 300 ecu. It will start only give abs error on dash.
    Jun 2016
    Budapest HUNGARY
    The Guzzidiag software connection MIU1 or Miu G3 mode the connection started ? need
    USB-KKL FTDIchip adapter
    gueswhat's Avatar
    Nov 2016
    World wide
    Quote Originally Posted by jaed View Post
    this is only for the model with the new vespa dash like 2017 and 2018
    but the new vespa hpe have lcd and that wont work and dash you will see ecu error
    so need to make this orginal transponder do you have open them up ?
  6. The Following User Says Thank You to gueswhat For This Useful Post:
  7. #5
    gueswhat's Avatar
    Nov 2016
    World wide
    Quote Originally Posted by f2f2 View Post
    this is a new model guzzidiag dont support this ecu
  8. #6
    Jun 2016
    Budapest HUNGARY
    Quote Originally Posted by gueswhat View Post
    Show me the picture how long does it take in this 2 mode : MIU1/ MIU-G3
    I know it's not on the list
    If something happens I'll send you a program.
  9. #7
    Jan 2016
    Hello,
    I got the same problem, do you find a solution ?
  10. #8
    Sep 2018
    Uk
    Anyone tried doing via diagnostic port? Or found any other way to read it?
  11. #9
    gueswhat's Avatar
    Nov 2016
    World wide
    i have fix it and make key on the unit this tread is done and made for help just contact
    the pins are not like the old unit the pins have change after i have read al info and i see the logic of the key cost me alittle time but i did it
    iam now bizzy for add more speed and tuning bikes with this unit
    for help just hit the
    thanks button and sent me a message(L)
  12. The Following 2 Users Say Thank You to gueswhat For This Useful Post:
    clubmanza (22nd January, 2024), MACKIE (31st July, 2023)
  13. #10
    MACKIE's Avatar
    Jan 2011
    Helion Prime
    Can you please ( if its not problem for you ) share where to dig in it and what transporder type is used ...
    Regards
    Mackie
    " I don't need help but difficulties. The harder the better. I work the best when in trouble."
  14. #11
    Jul 2010
    Hi, I’d like to know your solution for lost keys for Vespa Hpe models. I am also having trouble with the new models. I can already do the earlier ones with mui1and mui3 but cannot seem to access the Mui4.
  15. #12
    gueswhat's Avatar
    Nov 2016
    World wide
    Quote Originally Posted by MACKIE View Post
    Regards
    Mackie
    hello
    this model i read without open it up i read it by kline do
    you have pinout ? i have it if you dont have it tel me i wil share it
    its only read and done you are ready for make key or you need to send me a file
    i will make my key code for you and you program it and bike wil start
    i am now bissy whit the new model PGZ05 REV.E RISS3010 EFFI
    THIS is the newest around now but only for the 125cc model
  16. The Following 3 Users Say Thank You to gueswhat For This Useful Post:
    anthnyo (6th February, 2024), clubmanza (22nd January, 2024), hlwzombie (1st September, 2023)
  17. #13
    Junior Member anthnyo's Avatar
    Jan 2011
    west sussex
    do you know the pinout please thanks
  18. #14
    Sep 2021
    Hi, could you help me with read ecu 32m4g1 from vespa gts300 2020year ? I lost all key and want to add new one. My genuine device don't support this kind of ecu. Whitch tool you use to read it ? or if you have pinout i try use protocol like in older ecu. thx
  19. #15
    Aug 2022
    Hi, did you succeded with the new model PGZ05 RISS? Do you know its pinout?
