    Feb 2018
    PARAGUAY
    Default BMW X3 F25 KEYLESS NOT LOCK DOOR NO DETECT KEY INSIDE HELP PLEASE
    Hello friends, can someone help me, I have a problem with a bmw x3 f25 2017 with keyless go key, but the door lock does not work and does not detect the key inside the car, it just starts by approaching the key at the wheel and the only error code is This 801C20 ZGW FULL CENTRAL DEFAULT MEMORY, THERE IS NO FAILURE IN THE COMMAND UNIT any idea that can be already programmed another key and continues with the problem is frequency 315 and the key emits frequency
    Mar 2016
    Argentina
    I have The same problem any solution? please
    Jun 2013
    Same problem on a X5 2013-2017.
    Main Battery 12V clamp + and -
    First:
    The person only remove PLUS cable, and experience still same problem.
    Next try:
    Then remove also the "MINUS cable, at the same time.
    Together with the PLUS cable.
    Wait 30 seconds. etc.
    Battery clamps fitted, to the battery again.
    Car suddenly works with Keyless.
    And remote control on the key, start work again.
    This car, I think got an empty 12V main battery.
    They charge the battery.
    And at the same time, experience the error.
    The case was a second car dealer, who called in.
    And did this, by phone support.
    Which happen worked out, very well.
  4. The Following User Says Thank You to Weasel3 For This Useful Post:
    chris781 (21st May, 2024)
    Mar 2018
    UK
    If you programmed new key bear in mind that one of well know key suppliers sell "CAS4 433MHz" key that aren't suitable for FEM BDC
    they know very well that these keys arent suitable for any car but still sell them
  6. The Following User Says Thank You to Manta1600 For This Useful Post:
    Jul 2019
    Melbourne, Australia
    Sounds like wrong key to me like Manta surmises.
    There are multiple types of 433 & 315 mhz key. If original key board use ACDP or similar to write the other type to the board.
    Or try the Autel universal keys, I did one for a CAS4 just last week. Must use the BMW shape ones as they won't generate to the other shapes.
  8. The Following User Says Thank You to Spiritech For This Useful Post:
  9. #6
    Mar 2016
    Argentina
    thanks there I was able to do it with a new key
