Hi, you solved the problem, today it also spilled out
hi.
in mode j2534 the led is green , on elm 127 the led is red .
If the LED does not change color, then it is because you have a problem with the switch, open the interface and try to get something to make the switch work.
this is not about a switch, it happened when upgrading to ids 116, before it was ok , is the driver good, as shown to me in: device manager (Prolific USB-to-Serial Comm Port ) ????
hi friend change version a 113 and work now
Did u sort problem? My the same problem. Without update stop working. Light blinking on green but show message to check if its in j2534 mode.
Hi, were you able to solve the problem? I have two teams with the same problem. Apparently it crashes after an update. I reinstalled everything original but it does not give a solution, maybe we have to reprogram the micro
Hi, I tried to install old software, I changed the date to 2019, nothing changed, the problem is still the green led blinks quickly, maybe someone has some firmware to write to the device with the programmer ???
solved ??? my interface in blocked red led blinking
