Page 1 of 15 12345611 ... LastLast
Results 1 to 15 of 211
    yarokas's Avatar
    May 2019
    Portugal
    Default Jaguar XF 2013 front BCM dump DX23-14B476-BG
    Maybe some one have virgin or not virgin dump from the front bcm module (DX23-14B476-BG)?
    Can't read eeprom nor d-flash. Car wont start and saying no key found.
    Is it possible to restore it if i read the rear bcm?
    Aug 2009
    bloody hell am in the same boat? just disconnected the negative termianl? and all these problems? dx2314b476ag thats my part number for front bcm ? any dumps would be appricated?
    yarokas's Avatar
    May 2019
    Portugal
    Both batteries gone. I have dump gor your number, ill send you in the evening. Trying to resolve the ptoblem using the rear bcm.
    Aug 2009
    thanks waiting for dumps? when u mean use rear bcm should i get the eeprom and dflash from the rear bcm and use that on the front bcm?
    yarokas's Avatar
    May 2019
    Portugal
    Problem solved Used just rear eeprom not d flash and thing like 1 hour with JLR SDD updating security modules and programming new keys and it starts.
    Here is the dump for your part number, found in the net when looking for a dump. Dont know if it helps you but you can try.
  6. The Following 20 Users Say Thank You to yarokas For This Useful Post:
    adil_007 (1st August, 2020), antonypaul (4th July, 2023), atakan (4th December, 2023), AutoWOW (22nd May, 2023), BusCan (19th April, 2024), datapage (25th June, 2022), fred77 (5th October, 2020), Hayssam1 (25th June, 2021), jarecki55 (26th February, 2020), Landetos (14th March, 2023), lokher (26th April, 2022), mkopytekchi89 (30th June, 2022), moca (10th December, 2022), radion360 (12th December, 2023), talk2idris (26th November, 2022), v-diag (17th September, 2019), vanos batam (28th March, 2023), zar0079 (14th February, 2020)
  7. #6
    Aug 2009
    thanks already have this will try the rear bcm eeprom?
  8. #7
    yarokas's Avatar
    May 2019
    Portugal
    Any progress?
  9. #8
    Aug 2009
    Going to test later today contacted the guy who's files you have posted he said just us the eprom and p-flash from his files and code the keys? also have taken the eeprom from the rear bcm, so will try both option?
    will let you know the outcome. thanks
  10. #9
    yarokas's Avatar
    May 2019
    Portugal
    Today tried that eprom. Every thing worked except front whipers and module id error but disconected the battery and same, no key found.
  11. #10
    yarokas's Avatar
    May 2019
    Portugal
    If im right that dump is from a sedan. I manage to everything work except the rear window wiper and the washer pump. So im looking for dump from a 5 door car. Will be grateful if some one can share.
  12. #11
    Dec 2015
    Contact me. If washer pump is not working it means your bcm is still faulty. if you disconnect the battery, it will lost keys again. I have 100% working recovery solution.
  13. The Following 4 Users Say Thank You to 0n0t0le For This Useful Post:
    ecumix (2nd March, 2022), lokher (26th April, 2022), Rito (26th July, 2023), vasa (31st January, 2020)
  14. #12
    Mar 2010
    hi, DX23_14B476_AG jaguar bcm as you 0n0t0le post you got it fix ,i try to do some work on it but still cant make it fully working(central lock work on key but no ignition authorized),i wonder if you can have look it guys or give some hints?
  15. The Following User Says Thank You to mario.ie For This Useful Post:
    gerardo1 (15th April, 2023)
  16. #13
    Dec 2015
    Quote Originally Posted by mario.ie View Post
    your eeprom looks ok. you need correct programming it with sdd. i sent you pm.
  17. #14
    Jul 2017
    Quote Originally Posted by 0n0t0le View Post
    Send pm to you
  18. #15
    yarokas's Avatar
    May 2019
    Portugal
    After disconecting the battery everything still work ok. Was sometime ago, client took the car as is. But if you can share your solution would be great.
