Page 14 of 15 FirstFirst ... 49101112131415 LastLast
Results 196 to 210 of 214
  1. #196
    Jan 2024
    Dear anyone send me the virgin file for front bcm
  2. #197
    Jan 2024
    Can you share virgin file please
  3. #198
    Jun 2016
    Quote Originally Posted by KIM Young Jun View Post
    hello?
    Jaguar XF 2013 BCMB repair.
    This rear BCM
    I need help restoring it.
    The part number is [DX23-14D628-AG]
    no see . Do you mix front BCM and rear BCMB or KVM virgin files?
    thank you
    hi dear
    Did you solve your problem and how?
    i also face the same issue of BCMB, it block network once we disconnect socket from rare bcm then re connect scanner start communicate with other modules
    im looking for the virgin file rare BCM DX23-14D628-AG
    thanks and reagards
    We make A
    Living by
    What we get,
    but we make a
    life
    by
    What we give.
    -Winston Churchill
  4. #199
    Jun 2016
    Quote Originally Posted by foxtec800 View Post
    Hi , can someone check my BCMB , rear junction box files, Vin mismatch in plash and eep. i have sdd so can program if virgin files available
    eep and plash in rar file
    thanks guys
    hi dear, did you find the virgin file?
    im also stuck in rare BCM
    thanks and reagards
    We make A
    Living by
    What we get,
    but we make a
    life
    by
    What we give.
    -Winston Churchill
  5. #200
    Feb 2022
    South Africa, Durban
    Hi guys have virgin dumps of dx cx 9x and 8x front bcm and rear bcmb. Send me a private message for more info...keep in mind that you need to input your correct vin into both dflash and pflash and then resynch with SDD...proven 100% solution...I work on these cars everyday..
  6. #201
    Nov 2019
    Hi Guys.
    Here is the virgin front BCM
  7. The Following User Says Thank You to masterfamp For This Useful Post:
    Hardware (17th June, 2024)
  8. #202
    BusCan's Avatar
    Nov 2013
    Default Jaguar XF 2013 BCM
    Who can tell me if this EEprom is correct?
    DX23-14B476-BG
    Thank you very much
  9. #203
    Jan 2019
    Hello friends, I am stuck with one car. 2013 Jaguar xf.. Car came to my shop "no smart key found" message. I remove BCM and I read it and eeprom is good & not corrupt. So I connect newest SDD and try to "configure as new BCM" but always get error "failed to write target security identifier"
    So I remove the BCM and I write dx23-14b476-ag virgin EEprom and Pflash using vvdi. I install back in car and I get same problem "failed to write target security identifier"
    I remove KVM and I use ACDP on bench to write two new keys to it. Same result. I cannot write target id.. it fails on the first step so I am curious which module does it attempt to write first during the security - immobilization feature?
    Any help with this much appreciated. I have anydesk.
  10. #204
    Aug 2018
    Anyone have Jaguar XF DX23-14B476-BG virgin file?
  11. #205
    Feb 2018
    Talking BCM dump repair
    i need help repair the BCM dumps attached.
    thanks.
  12. The Following User Says Thank You to ahmadarifai For This Useful Post:
  13. #206
    Jun 2018
    England
    Quote Originally Posted by ahmadarifai View Post
    thanks.
    Be more active and helpful.
    Here is your file
    dont forget to thank and rep people that help you too
    If i helped please press the thanks button
  14. The Following 2 Users Say Thank You to paulsta For This Useful Post:
    ahmadarifai (29th May, 2024), Hardware (17th June, 2024)
  15. #207
    matej505's Avatar
    Dec 2019
    Warszawa Polska
    Hello. Can you help me? 3 days and nothing works. Milions eeproms virgin, dflash partition and XF dont start. Always if i configure new module is communicate FAILE TO WRITE TARGET SECURITY. All the times. I did virgin many times but on this ~~~~ing one i cant do. Kvm is good. We dont know with my friend what else we can do?
    Please help us
  16. The Following User Says Thank You to matej505 For This Useful Post:
    ruwi (16th June, 2024)
  17. #208
    Oct 2012
    Somewhere in Africa...
    Quote Originally Posted by matej505 View Post
    Please help us
    Same situation. Here's my story. Car went to another country to have engine change, battery was disconnected for an extended period. Then when they realised that keys were not detected, someone came with an Autel tool (apparently). They replaced GSM and tried to program, this failed. We were called in, found hazard lights blinking and brake lights stuck on. When we repaired FBCM at first ignition will come on then go off, keys couldn't program. Then we flashed files from another vehicle on the RBCM (different VIN), managed to program this module back in with VIN bypass. Then flashed front BCM with virgin file (DX23-14B476-AG), I keep getting Target Identifier write issue, this appears to be from KVM and IPC, even if I write virgin files into both KVM and FBCM I still have the same error. As I write this, we are writing a file from another XF which has the same part numbers from last year, and try to program with VIN Bypass again. Right now it's fingers crossed with this one.
  18. #209
    Jul 2019
    I am on the same boat as well, Not able to do it with virgin files. Everytime I get Failed to write Security Identifier. Also Car have only one key and it shows no key is programmed now. Stuck at this for weeks now no solution so far.
  19. #210
    matej505's Avatar
    Dec 2019
    Warszawa Polska
    Problem solved. Try do virgin on bcm and bcmb then first do IPC. Ignition is on and car crank and drive.
  20. The Following User Says Thank You to matej505 For This Useful Post:
