Page 3 of 15 FirstFirst 1234567813 ... LastLast
Results 31 to 45 of 214
  1. #31
    Oct 2017
    Australia
    Can you tell me what files are programmed to the vehicle because this has no vin numger in it (eeprom read after writing).
  2. #32
    Aug 2012
    Ah sorry. Please ignore the files which mention 'after writing' as I was just testing. The other reads are what is currently in car. Using SDD, when I try to program keys/KVM,front BCM, or immobiliser function I get: 'failed to write target identifier'.
  3. #33
    Oct 2017
    Australia
    When programming BCM using SDD it needs to a virgin BCM. It won't program it if its got a vin number in it.
  4. #34
    Aug 2012
    I have flashed the virgin file from this thread and tried, without success 😐
  5. #35
    topclef's Avatar
    'failed to write target identifier', means BCM faulty or corrupted , write virgin dumps P-flash + D-flash , configure it as new module using SDD , happen to me and i did it succefuly .
    I forgot one thing , rear BCM and front BCM must have the last SW level , otherwise will not work
    make update for rear BCM
    Good luck
    you have two choices in the morning: go back to bed and continue dreaming, or you get up to make your dreams come true
  6. The Following User Says Thank You to topclef For This Useful Post:
    MBGL (5th February, 2021)
  7. #36
    Oct 2017
    Australia
    topclef is right, you need to write virgin dumps. Existing BCM eeprom and Existing BCM P Flash are not virgin dumps.
  8. The Following User Says Thank You to Paddjohn For This Useful Post:
    mkopytekchi89 (26th May, 2022)
  9. #37
    Aug 2012
    Thank you. I would be very grateful for virgin files for rear BCM and I haven’t got D flash data at all 👍
  10. #38
    Aug 2012
    .... I was able to update the rear BCM no problem, so the reads I posted are latest sw.
  11. #39
    topclef's Avatar
    Quote Originally Posted by Plowman View Post
    in this case , write virgin front BCM dumps and reconfigure it as new , good battery and charger ...
  12. #40
    topclef's Avatar
  13. The Following User Says Thank You to topclef For This Useful Post:
    ecusouthservice (25th December, 2022)
  14. #41
    Aug 2012
    Every time I try to update KVM or program keys I get this message. Is this normal?
  15. #42
    Aug 2012
    Quote Originally Posted by topclef View Post
    Good luck
    Could you please forward virgin dumps (including D Flash)?
  16. #43
    Aug 2012
    Good luck
    Could you please send virgin D Flash?
  17. #44
    metalik's Avatar
    Mar 2012
    Hello ,
    Jaguar XF250 , NO KEY DETECTED , common problem when disconnectin the Battery
    how can check these files from BCM Jaguar XF if correct , can read only eep + P-flash ,can't read D-flash with VVDI-Prog , when i try to read D-flash message Partition D-flash 0 sector 0K , eeprom 8 Sector 2K Check error
    thanks in advance
    Hello i have a same problem in same car, its any way to restore a d-flash from eeprom or p-flash. I have d-flash from rfa module. Any sugegestion?
  18. #45
    topclef's Avatar
    Quote Originally Posted by metalik View Post
    better , try to read front BCM D-Flash 32k , i can restore eeprom for you
    if you cannot read it , use these files EEP+FLASH and reconfigure the BCM using SDD
  19. The Following 4 Users Say Thank You to topclef For This Useful Post:
    BusCan (19th April, 2024), Hayssam1 (24th June, 2021), metalik (8th May, 2021), sraj (1st February, 2024)
