Page 4 of 14 FirstFirst 123456789 ... LastLast
Results 46 to 60 of 202
  1. #46
    metalik's Avatar
    Mar 2012
    Quote Originally Posted by topclef View Post
    better , try to read front BCM D-Flash 32k , i can restore eeprom for you
    if you cannot read it , use these files EEP+FLASH and reconfigure the BCM using SDD
    Hello thx for reply, i read a front bcm and i have eeprom and p-flash, i cant read a d-flash. I used a vvdi prog.
  2. #47
    May 2017
    Hello.
    I uploaded the "virgin" files in BCM and after adding a new bcm in SDD the car ignites etc. but there are errors and there is still no VIN in bcm and one key works :-)
    Any tips? For me, the content of the EEE is probably damaged and it cannot be recovered
    (it is impossible to read the D-flash only EEE)
  3. #48
    May 2017
    As he wrote topclef upload virgin files from this thread. I have the same problem and the car is already starting but not everything is still OK and I ask what and how.
    But in my opinion the content of the EEE is not damaged. your vin SAJAA05K1EDU15843
  4. #49
    Jul 2017
    I have a 2013 xf250 estate with front bcm DX23-14B476-BG, not recognising keys and no comms with lots of modules after disconnecting battery, I read with vvdi prog, the d-flash was 32kb, when I went to read eee it gave me the option to set the partition size, I read it several ways, anyway I got eeprom repaired from d-flash, wrote back 2kb file to eeprom, on writing it gave me no option to set partition, it did so automatically but wrote okay, after writing back I read d-flash again and there is no data in there, from digging around I am led to believe that if things are okay with the eeprom the d-flash should contain no readable data so in short a healthy bcm should have:
    d-flash 0Kb
    eeprom 2Kb
    p-flash 256Kb
    Someone correct me if this is wrong
    On this car after I connect bcm back, radio,headlights and ignition came to life for a few seconds and immo light started flashing, then ignition turned off and I got the key not recognised msg in cluster, I think I need sdd to go any further on this, I will report back my findings in future
  5. The Following 3 Users Say Thank You to Colin C For This Useful Post:
    BusCan (19th April, 2024), chap2017 (29th January, 2022), fred77 (8th March, 2023)
  6. #50
    May 2017
    Give eeeprom dump
  7. #51
    Jul 2017
    Quote Originally Posted by blejku View Post
    Give eeeprom dump
    Here is repaired eeprom
  8. #52
    May 2017
    with password?
  9. #53
    Jul 2017
    Apologies, here is file
  10. #54
    May 2017
    I think the content is ok. Without SDD, it probably won't work. I have a lot of equipment but I managed only to the end through SDD. What kind of diagnostic equipment do you have? What are they serving? vin numbers from front and rear BCM?
  11. #55
    Jul 2017
    The content looks okay but hard to tell, vin&part numbers are correct, I have plenty of diag equipment, tried launch, autoland, autel..., I think sdd is the only way out, if that doesn’t work as is, I will try virgin file if I can find, I am getting sdd set up shortly
    Can see vin in bcms
  12. #56
    May 2017
    With the help of the X431 it will only get worse so watch out :-)
    I saw module memory errors only when using SDD. Let me know when you have it. my x250 has already gone into the world :-p today.
    Virgin not entirely, but it is here in the thread.
  13. #57
    Jun 2021
    TURKEY
    Hi friends.
    I have a 2013 xf too. does not recognize the key after battery disconnection. In my check with sdd, I get problems with the front bcm module as in the picture. As I read and understand from the forum, it is necessary to load virgin files into bcm. Where can I find the virgin file? My friend who does the repair of the car ecu said, I'll do this upload. I'd be happy if you could help.sdd screenshot.jpg
  14. #58
    Oct 2017
    Australia
    Can you post D Flash and I'll to recover your EEE. Yours is corupt.
  15. The Following User Says Thank You to Paddjohn For This Useful Post:
    chap2017 (28th January, 2022)
  16. #59
    Jul 2017
    Thanks for help blekju, solved with eeprom repaired, update kvm then configure bcm as new module and run immo function
  17. #60
    Jun 2021
    TURKEY
    HELLO
    HOW DO I GET D FLASH? HOW SHOULD I APPLY?
    Quote Originally Posted by Paddjohn View Post
