Dear anyone send me the virgin file for front bcm
Can you share virgin file please
hi dear
Did you solve your problem and how?
i also face the same issue of BCMB, it block network once we disconnect socket from rare bcm then re connect scanner start communicate with other modules
im looking for the virgin file rare BCM DX23-14D628-AG
thanks and reagards
We make A
Living by
What we get,
but we make a
life by
What we give.
-Winston Churchill
Hi guys have virgin dumps of dx cx 9x and 8x front bcm and rear bcmb. Send me a private message for more info...keep in mind that you need to input your correct vin into both dflash and pflash and then resynch with SDD...proven 100% solution...I work on these cars everyday..
Hi Guys.
Here is the virgin front BCM
Who can tell me if this EEprom is correct?
DX23-14B476-BG
Thank you very much
Hello friends, I am stuck with one car. 2013 Jaguar xf.. Car came to my shop "no smart key found" message. I remove BCM and I read it and eeprom is good & not corrupt. So I connect newest SDD and try to "configure as new BCM" but always get error "failed to write target security identifier"
So I remove the BCM and I write dx23-14b476-ag virgin EEprom and Pflash using vvdi. I install back in car and I get same problem "failed to write target security identifier"
I remove KVM and I use ACDP on bench to write two new keys to it. Same result. I cannot write target id.. it fails on the first step so I am curious which module does it attempt to write first during the security - immobilization feature?
Any help with this much appreciated. I have anydesk.
Anyone have Jaguar XF DX23-14B476-BG virgin file?
i need help repair the BCM dumps attached.
thanks.
ahmadarifai (29th May, 2024)
Hello. Can you help me? 3 days and nothing works. Milions eeproms virgin, dflash partition and XF dont start. Always if i configure new module is communicate FAILE TO WRITE TARGET SECURITY. All the times. I did virgin many times but on this ~~~~ing one i cant do. Kvm is good. We dont know with my friend what else we can do?
Please help us
ruwi (Yesterday)
Same situation. Here's my story. Car went to another country to have engine change, battery was disconnected for an extended period. Then when they realised that keys were not detected, someone came with an Autel tool (apparently). They replaced GSM and tried to program, this failed. We were called in, found hazard lights blinking and brake lights stuck on. When we repaired FBCM at first ignition will come on then go off, keys couldn't program. Then we flashed files from another vehicle on the RBCM (different VIN), managed to program this module back in with VIN bypass. Then flashed front BCM with virgin file (DX23-14B476-AG), I keep getting Target Identifier write issue, this appears to be from KVM and IPC, even if I write virgin files into both KVM and FBCM I still have the same error. As I write this, we are writing a file from another XF which has the same part numbers from last year, and try to program with VIN Bypass again. Right now it's fingers crossed with this one.
I am on the same boat as well, Not able to do it with virgin files. Everytime I get Failed to write Security Identifier. Also Car have only one key and it shows no key is programmed now. Stuck at this for weeks now no solution so far.
Problem solved. Try do virgin on bcm and bcmb then first do IPC. Ignition is on and car crank and drive.
ruwi (Yesterday)
