Results 1 to 15 of 15
    Feb 2018
    Default Alfa Romeo 2.4 JTDM 200hp stage 1 overload check or help please
    Please help
    Alfa 2.4 jtdm 200hp
    Probably overload, what should I improve, the car enters the emergency mode. Stage 1 file crc B6C7 ecmtitanium.
    Turbo preassure, Limiter of turbo preassure ist nogood?
    Thx
    a500tut's Avatar
    Jun 2017
    Belarus
    Hi mate, i checked you files, this is bad tuning, stock boost is 2.4 bar, limit guard 2.7 bar, after stage you have 2.9 bar, it's crazy
    If I helped you, click thanks and reputation
    Feb 2018
    Quote Originally Posted by a500tut View Post
    So how do I do 2700 will not turn on emergency mode?
    a500tut's Avatar
    Jun 2017
    Belarus
    Now upload stock file, if you don’t know how to remap this car, it’s better to leave it as it is, so you can also ask someone to make a good stage1.
  5. The Following User Says Thank You to a500tut For This Useful Post:
    Trice1001 (15th September, 2019)
    Feb 2018
    So i will ask for stage 1 if anyone helps. As many as possible.
    so I will ask for stage 1 if anyone helps. As many as possible
    Aug 2018
    Austria
    Default Try and Report
    Hello!
    File is with your DPF-Off Solution!
    After Press Thanks Button you get Pass in PM
    greetings Mario
  8. The Following User Says Thank You to Mariobozze For This Useful Post:
    teedy6 (16th September, 2019)
  9. #7
    Feb 2018
    Quote Originally Posted by Mariobozze View Post
    Hello!
    greetings Mario
    I have dpf off. I needy more power.
  10. #8
    May 2019
    Macedonia
    Default alfa
    Try this mate pass in pm
  11. The Following User Says Thank You to damjantuze For This Useful Post:
    teedy6 (18th September, 2019)
  12. #9
    Aug 2018
    Austria
    Hello!
    Have you write File in Car!?
    I write this File is with your dpf off solution!
    I only make Stage 1!
    greetins
  13. #10
    Feb 2018
    Hello!
    greetins
    Hello
    I savedthe file and there is almost nodifference. I need more power.
    thx
  14. #11
    Feb 2018
    Quote Originally Posted by damjantuze View Post
    You send pass?
  15. #12
    a500tut's Avatar
    Jun 2017
    Belarus
    Quote Originally Posted by teedy6 View Post
    You send pass?
    Pass in pm. you have full box, please do clean.
  16. #13
    Feb 2018
    Please help
    Alfa 2.4 jtdm 200hp
    Thx
    Hello
    Why cuts off at 3000 revolutions
    and the car goes out?
    Is there a stop somewhere?
    Where, what address?
    I don't care about the engine as much power as possible
  17. #14
    May 2019
    Antoine still have stage one file just wanna compare with my stage one file
    Thanks !
  18. #15
    Mar 2018
    hello. can you please me the pass?
    thank you
