Results 1 to 4 of 4
    Jun 2010
    Usa
    Default VVDI2 errors and successes
    Everyone can write here what needs to be improved or what is not possible after the VVDI2 update. It can also be reported what is all about VVDI2.
    BMW CAS 2
    BMW CAS 2 connected via OBD
    The CAS ID and data can be read.
    Miles and ISN DME - CAS are read.
    No EEprom is read with the current ID.
    And you should read the whole thing with the VVDI 2 adapter.
    Jun 2010
    Usa
    CAS2 has current UIF
    CAS with VVDI2 Adapter
    You can read CAS2 ID here.
    Miles are not read.
    CAS-DME ISN is read.
    EEprom is not read either.
    It can not be that here you developed a software that Miles and EEprom can not read.
    Here should be greatly improved.
    Jun 2010
    Usa
    So here is an old CAS2
    Has not received an update.
    ES can read the Miles and DME-CAS ISN via OBD.
    For EEprom the VVDI2 adapter should be used.
    With VVDI2 adapter
    It can be read Miles, DME-CAS ISN and EEprom.
    Jun 2010
    Usa
    What is missing here is CAS2
