Results 1 to 1 of 1
    Sep 2019
    Default Honda CRV Immo diffilculties
    Hi guys...Im a new user here and fairly new to Immo programming...Can someone assist with my issue. I have a 1998 CRV Honda with all keys lost. I took a read off the Bakom HLI 502 immo and got key mumbers out of it using Immo service tool 1.2. I programmed the chip (megamos 13 T5 with all the 4 key numbers on 4 seperate occasions (pic enclosed) and car would not put security lamp out or start. I then read the bin file with my Zedbull mini and programmed the key again.....Completely different number to the other 4. Security lamp goes out but still no crank or start. I have also enclosed 16 bit and 8 bit version of the bin file. Pretty sure Im dealing with a 16 bit 93c46. If I remove immo board oiut of engine ecu and bypass start wire at immo box car does run fine. Any ideas please on what is wrong. Rar file attached with files cheers and thanks in advance.
