Results 1 to 15 of 20
Thread: CAS3 0L15Y dead
    POLAND
    Default CAS3 0L15Y dead
    Hi.
    Customer states after battery went dead car stop starting .No response from cas ,dead dashboard ,not recognizing orginal key not even showing message when i put different key . What i did ,read eeprom with r260 rosfar ,write different epprom from spare CAS that i have with working key and orginal cas is back to life,dash lights cranking ok but no start of course -ISN VIN not matching .But that tells me my flash is "Ok "?
    I read files with Rosfar - but cant write flash -r260 not supporting writing flash ,only eeprom .
    Other 2 files I read with xprog
    Can somebody correct my files .
    mcu
    MC9S12XDP512
    MASK 0L15Y
    Jun 2018
    England
    Quote Originally Posted by Bart86 View Post
    Hi.
    mcu
    MC9S12XDP512
    MASK 0L15Y
    Where are you located Bart?
    Sent from my Pixel 2 XL using Tapatalk
    If i helped please press the thanks button
    p1et's Avatar
    Oct 2013
    Of course you can write flash with r260
  4. The Following User Says Thank You to p1et For This Useful Post:
    igorr (18th September, 2019)
    POLAND
    Quote Originally Posted by p1et View Post
    This mcu is not supported in r260 for writing flash. Only eeprom.
    Sent from my VTR-L09 using Tapatalk
    pepi's Avatar
    Use R270 , xprogM or VVDI prog
    Usa
    Hi.
    mcu
    MC9S12XDP512
    MASK 0L15Y
    EEprom file where read with Xprog is OK.
    The other EEprom file can not be read and is bad.
    kazikk's Avatar
    Try this eeprom
  9. The Following User Says Thank You to kazikk For This Useful Post:
    Bart86 (18th September, 2019)
  10. #8
    POLAND
    Quote Originally Posted by kazikk View Post
    Try this eeprom
    Thanks Kazik for trying but still no luck ,cas is still dead
  11. #9
    POLAND
    Quote Originally Posted by hojo25 View Post
    Other eeprom is read by r260 and is in diffrent format but read is ok
  12. #10
    Usa
    The EEprom is fine.
    So the flash will be broken.
    Try to reach Tool32 CAS.
    If that works flashing with Winkfp again.
  13. #11
    POLAND
    That wouldnt make sens. I use my donor eeprom +key and i write to orginal cas and everything start working . When i use epprom from orginal cas and transfer to donor CAS is dead .
  14. #12
    Usa
    And is the ignition on?
  15. #13
    POLAND
    With donor eeprom ignition ON and cranking but no starting. With Ori file no response on cluster at all . But u can communicate with Cas but no errors and not recognizing any key and cluster not even showing u that u using wrong key
  16. #14
    Usa
    Did you send EEprom from CAS Original?
    And EEprom used by CAS?
  17. #15
    POLAND
    Only orginal files
