Ford Mondeo 1.6
Results 1 to 3 of 3
Thread: Ford Mondeo 1.6
    Croatia
    Default Ford Mondeo 1.6
    Hello
    I get one Ford Mondeo 1.6 gasoline 2007-2008.year.
    Ecu is Siemens VDO EMS2101 S180016002G.
    The dtc are P060A - Internal Control Module Monitoring Processor Performance.
    I read about his DTC and someone solved this problem by flushing Throttle and someone replace all 4 coils,what is your expirience about this problem if you had it ? do you have any advice ?
    Thank you ...
  2. The Following User Says Thank You to Mezz_cro For This Useful Post:
    mastaflex (8th July, 2020)
  3. #2
    Quote Originally Posted by Mezz_cro View Post
    Hello
    Thank you ...
    I think Ecu problem.
    Meat-Head's Avatar
    Idea to use different scan tool.
    not sure on vehicle, but one when battery flat gives an simular error, charge battery it drops below. 9 volts
    On cranking.
    Then take 2 aspirin pills see what happens
